Energy of a car going up a hill
  • Thread starter Thread starter anthonyk2013
    Car Energy Hill
To calculate the energy required for a car to accelerate uphill, both kinetic and potential energy must be considered. The kinetic energy (KE) is calculated using the formula KE=1/2m(V2^2-V1^2), resulting in 374,922 J for the speed increase from 15 km/h to 75 km/h. Additionally, potential energy (PE) due to the vertical rise of 55 m is calculated using PE=mgh. The total energy required combines both kinetic and potential energy, confirming the need to include the height in the overall energy calculation. Understanding both energy types is essential for accurate results in this scenario.
anthonyk2013
Not using homework template due to originally being posted in a different forum.
find the energy of a required to accelerate a 1800kg car from 15 km/h to 75km/h an up hill road with a vertical rise of 55m
KE=1/2m(V22-V12)
KE=1/2(1800)(20.832-4.162)
KE=1/2(1800)(433.88-17.30)
KE=1/2(1800)(416.58)
KE=1/2(749844)
KE=374922 J
I'm wondering if I'am on the right track, no sure how to bring the rise into the problem.
+ mgh
KE=1/2m(V22-V12)+mgh ?
Energy = Kinetic energy + Potential energy
Potential energy = mgh
Likes anthonyk2013
Thank you
