What is the Donor-Electron Ionization Energy of Silicon Crystal?
  • Thread starter Thread starter ee1215
    Electron Energy
ee1215
Find donor-electron ionziation energy of silicon crystal. Electron effective mass mc=.98mo and dielectric constant ε/εo=12.3
I use the ED=-(1/4πε)2*[(mc*e4) / (2*(h/2π)2)]
My answer of -1.415x10-54 does not seem right. I solved for mc and ε from given equations in the problem and plugged in. Is this correct or have I made a mistake?
What you did is correct in principle. You could made same calculation error or plugged in wrong value for m0. Show your data and calculation. And what unit of energy did you use?
ehild
Well, using the ED formula mentioned above. I solved for mc = .98*9.1094x10-31 = 8.927x10-31kg and solved for ε=12.3*8.854x10-12 = 1.089x10-10F/m. Plugged those two equations into ED, and also h-bar = 1.054x10-34Js and e=1.6022x10-19C, I got the answer I mentioned above in my calculation.
Your result is impossible. Count the exponents: 4*(-19)+(-31)-(2*(-12)+2*-(34)). It is -15. Multiply the numbers, this gives a magnitude of 10-5. So the result is of magnitude 10-20Joule.
ehild
You are correct. Even though I thought I double checked me answer before I posted the question, I just did the calculation and got -1.4138x10-20. This is more reasonable?
Sure!:smile:If you feel the result impossible try to estimate its magnitude without calculator.
ehild
Hi, I had an exam and I completely messed up a problem. Especially one part which was necessary for the rest of the problem. Basically, I have a wormhole metric: $$(ds)^2 = -(dt)^2 + (dr)^2 + (r^2 + b^2)( (d\theta)^2 + sin^2 \theta (d\phi)^2 )$$ Where ##b=1## with an orbit only in the equatorial plane. We also know from the question that the orbit must satisfy this relationship: $$\varepsilon = \frac{1}{2} (\frac{dr}{d\tau})^2 + V_{eff}(r)$$ Ultimately, I was tasked to find the initial...
The value of H equals ## 10^{3}## in natural units, According to : https://en.wikipedia.org/wiki/Natural_units, ## t \sim 10^{-21} sec = 10^{21} Hz ##, and since ## \text{GeV} \sim 10^{24} \text{Hz } ##, ## GeV \sim 10^{24} \times 10^{-21} = 10^3 ## in natural units. So is this conversion correct? Also in the above formula, can I convert H to that natural units , since it’s a constant, while keeping k in Hz ?
