How Is Energy Transformed in a Satellite's Decaying Orbit Due to Air Friction?
In summary: Suppose we consider a slightly different situation. Suppose an object with the same mass as the satellite is momentarily stationary above the surface at the same height as the satellite orbit and falls straight down to the surface. Ignoring air friction, what will be its KE and velocity at impact? Where did that KE come from? It's initial orbital KE was zero...
Zynoakib
70
A 500-kg satellite is in a circular orbit at an altitude of
500 km above the Earth’s surface. Because of air friction,
the satellite eventually falls to the Earth’s surface,
where it hits the ground with a speed of 2.00 km/s. How
much energy was transformed into internal energy by
means of air friction?
Total Energy of satellite = PE = KE
= G(mass of satellite)(mass of Earth)/ - 2 (Earth's radius + orbit's height)
= -1.45 x 10^10 J
KE before crash = 0.5 (500)(2000)^2 = 1 x 10^9 J
Energy loss due to friction
- 1.45 x 10^10 - 1 x 10^9 = 1.55 x 10^9 J
But the answer is 1.58 x 10^9 J, what is missing?
Thanks in advance!
Did you account for all the energy? What about the potential energy change from orbit to surface?
Why do I need to include PE change? Shouldn't all the PE energy be converted to KE right before it crashes? So the PE change will be included into KE.
PE will be changed to KE continuously as the object changes its radial position. The KE it gains as a result must figure into what remains at the end of its journey.
Likes Zynoakib
1. What is the energy of a planetary orbit?
The energy of a planetary orbit refers to the total amount of energy required for a planet to maintain its orbit around a central body, such as a star or a planet. This includes both the kinetic energy of the planet's motion and the potential energy due to its position in the gravitational field.
2. How is the energy of a planetary orbit calculated?
The energy of a planetary orbit can be calculated using the equation E = K + U, where E is the total energy, K is the kinetic energy, and U is the potential energy. The kinetic energy can be calculated using the planet's mass and velocity, while the potential energy is determined by the distance between the planet and the central body.
3. What is the relationship between the energy of a planetary orbit and its distance from the central body?
According to the law of conservation of energy, the total energy of a planetary orbit remains constant. As the distance between a planet and its central body increases, the potential energy also increases, but the kinetic energy decreases in order to maintain a constant total energy.
4. How does the energy of a planetary orbit affect the planet's speed?
The energy of a planetary orbit is directly related to the planet's speed. As the energy of the orbit increases, the planet's speed increases as well. This is because a higher energy orbit requires a greater velocity for the planet to maintain its distance from the central body.
5. Can the energy of a planetary orbit change over time?
Yes, the energy of a planetary orbit can change over time due to various factors such as gravitational interactions with other bodies, changes in the planet's mass or velocity, and external forces like radiation. However, the total energy of the orbit will always remain constant due to the law of conservation of energy.
