Energy partitioning (Attenuation)
The discussion centers on calculating total amplitude attenuation of a seismic wave reflected at multiple interfaces with a reflection coefficient of 0.15. Participants debate whether the attenuation equation should be applied four or five times, leading to estimates of 9% or 11.25% amplitude loss, respectively. The consensus leans towards using the equation four times, as the wave transmits through four interfaces and reflects at the fifth before returning. Clarifications confirm that the wave is transmitted through the first four interfaces, reflected at the fifth, and then transmitted back through the same four. The final agreement supports the calculation of 9% attenuation based on four applications of the equation.
stubbe11
A seismic wave travel from surface, is reflected at the fifth of a series of horizontal interfaces. Each has a reflection coefficient "R" of 0.15. What is the total attenuation in amplitude caused by energy partitioning at all encountered interfaces, when the wave returns to the surface?
total loss = (1-R)(1+R) = (1-R^2) [for one layer]
We have a discussion here, where some argue that the equation should be used 4 times, hence the answer is 9% of the amplitude has been attenuated. And some who argue that it should be used 5 times (11.25%). Any inputs as what could be the correct one?
Up to what point in the whole process? It has to be transmitted through 4, reflected at 1, then transmitted back through the first 4, no? Or have I misunderstood the question?
Thanks for your interest and time.
Well, it seems like you understood it like I did. Transmitted through 4 interfaces and reflected on the 5th, then transmitted back up to the surface through the same 4 interfaces. So would you agree on 4 times then?
Yes.
haruspex said:
Yes.
Big thanks!
Thread 'Collision of a bullet on a rod-string system: query'
In this question, I have a question. I am NOT trying to solve it, but it is just a conceptual question. Consider the point on the rod, which connects the string and the rod. My question: just before and after the collision, is ANGULAR momentum CONSERVED about this point? Lets call the point which connects the string and rod as P. Why am I asking this? : it is clear from the scenario that the point of concern, which connects the string and the rod, moves in a circular path due to the string...
