How Do You Calculate Energy Supplied in Different Time Intervals of a Circuit?
  • Thread starter Thread starter smith5753
    Circuit Energy
To calculate the energy supplied in a circuit, the instantaneous power p(t) is determined by multiplying voltage v(t) = ½ t Volts and current i(t) = 12t - 4t² Amps, resulting in p(t) = 6t² - 2t³ watts. The next step involves finding the energy supplied over specified time intervals: 0 < t < 3, 3 < t < 4, and 0 < t < 4, by integrating p(t) over these ranges. There is confusion about the integration limits, with clarification needed that integration should only occur from the specified lower limit to the upper limit of each interval. The discussion emphasizes that the polynomial power function will approach infinity as t approaches infinity. Proper integration techniques are essential for accurately calculating the energy supplied in each time interval.
smith5753
For the element shown below, v(t) = ½ t Volts and i(t) = 12t-4t2 Amps.
a)Find the instantaneous power p(t) as a function of time.
b)Find the energy supplied (this value can be negative or positive for each range) to the element for the following three time ranges:
0 < t < 3, 3 < t < 4, 0 < t < 4, those are less than or equal to.
There is a picture of the circuit that show that it satisfies the Passive Sign Convention.
P(t) = V(t) i(t)
w= the integral of P(t)
for part a. I multiplied the given V times the i and found p(t) to = 6t^2 - 2t^3 watts.
for part b. I attempted to take the integral of P(t) from the first point listed; 0 < t < 3
I don't understand the integration. Do i integrate from infinitie to 0, then from 0 to 3, and then from 3 to infinitie?? I am so lost at this point.
Just integrate form 0 to 3
EDIT: also if you have infinity in the limits, the polynomial will tend to infinity as t→ inf.
Thread 'Trying to understand the logic behind adding vectors with an angle between them'
My initial calculation was to subtract V1 from V2 to show that from the perspective of the second aircraft the first one is -300km/h. So i checked with ChatGPT and it said I cant just subtract them because I have an angle between them. So I dont understand the reasoning of it. Like why should a velocity be dependent on an angle? I was thinking about how it would look like if the planes where parallel to each other, and then how it look like if one is turning away and I dont see it. Since...
