Energy to separate one molecule of water from a single neighbour
The discussion revolves around estimating the energy required to separate one water molecule from its neighbors in ice, with a calculation suggesting approximately 4.5 E-20 J. The reasoning involves using the total heat needed to convert ice to vapor and factoring in the number of neighboring molecules. There is a debate about the validity of multiplying by two in the calculation, as each molecule is bonded to four neighbors, and the concept of "outermost bonds" is clarified as non-existent in the molecular structure of ice. Participants emphasize that the structure of ice is uniform, with each molecule consistently bonded to four others. Overall, the conversation seeks to refine the calculation method and clarify misconceptions about molecular bonding in ice.
johnconnor
Question:
The amount of heat required to convert 1g of ice into vapour is approx. 3000J. Estimate the energy required to separate one molecule from a single neighbour, assuming that in ice, each H2O molecule has four nearest neighbours. [Mr(water) = 18)
My reasoning:
3000 x 2 / [1/18 mole x NA x 4] = 4.5 E-20 J
Because each molecule is attracted to 4 other molecules -- hence the product of the number of water molecules with 4. And since I'm looking for the energy required to separate one molecule from a single neighbour, I multiplied the division by 2.
Is this reasoning valid? Haven't we ignored the unused bonds of the water molecules at the outermost part of the ice cube? How significant is it to take into consideration those unused bonds?
If the reasoning is wrong, could anyone please point to me the proper way of attempting the question (rather than getting a fortuitous answer)?
Anyone?
Bump?
I think the reasoning is almost correct. I don't understand why you multiplied by two, though. Each molecule has four neighbors. And the term you get without multiplying the two, is the binding energy between them for each neighbor.
Also, there are no 'outermost bonds'. It is somewhat like a football structure, closed on itself, so each ice molecule is joined to four others.
