Engine thermal efficiency and Volume ratios
The discussion centers on deriving the thermal efficiency of a cyclic process involving a perfect gas, characterized by three distinct stages: cooling at constant pressure, heating at constant volume, and adiabatic expansion. The proposed expression for thermal efficiency is η = 1 - γ(r-1)/(rγ-1), but the calculations presented lead to a different result, prompting confusion about the assumptions made, particularly regarding the adiabatic process. Participants emphasize the importance of using the adiabatic condition, PVγ = K, to relate pressures and volumes effectively. There is also a focus on ensuring that heat exchanges are correctly represented in terms of absolute values to align with the expected efficiency formula. The conversation highlights the complexities of thermodynamic calculations and the necessity of careful assumptions in deriving accurate results.
sandpants
The question:
A perfect gas undergoes the following cyclic processes:
State 1 to 2 cooling at constant pressure.
State 2 to 3 heating at constant volume.
State 3 to 1 adiabatic expansion.
Deduce an expression for the thermal efficiency of the cycle in terms
of r the volume compression ratio (r=V1/V2) and γ (where γ = ratio of specific heats Cp/Cv)
My attempt at the solution:
First I tried sketching the cycle
Bare with me as I present you the silly symbol art.
P
3.
|...'-._
2<---------':.1 v
I'd like to work in specific terms
As it is a perfect gas
P1v1= RT1
P1v2= RT2
P2v2= RT3
Heats from 1->2, 2->3, 3->1
Q1->2=Cp(T2-T1)
Q2->3=Cv(T3-T2)
Q3->1 = 0 ; adiabatic.
Also, polytropic relations
v2/v1 = (P1/P2)1/n
as r = v1/v2⇔ r = (P2/P1)1/n
∴ rn = P2/P1 and
1/rn = P1/P2
Substituting Ideal Gas expressions in terms of Tn
Q1->2=Cp((P1v2-P1v1)/R)
Q2->3=Cv((P2v2-P1v2)/R)
Thermal efficiency
This is what I am unsure off. I begin assuming quite a few things. First I assume that heat in the cooling process is the equivalent of heat escaping to a cold reservoir; coincidentally, heat from the pressurization is the heat INPUT from the hot reservoir. As such:
η = [Q2->3 - Q1->2]/Q2->3
η = 1 - Q1->2/Q2->3
∴ η = 1 - Cp(P1v2-P1v1)/Cv(P2v2-P1v2)
η = 1 - γ((P1v2-P1v1)/(P2v2-P1v2))
From here:
P1v2/P2v2-P1v2 = P1/(P2-P1) = 1/rn-1
And
P1v1/P2v2-P1v2 = r/(rn-1)
My Result
η = γ(1-r)/(rn-1) =/= η = 1 - γ(r-1)/(rγ-1)
Can I assume n=γ in this situation? only 1 process is adiabatic.
Science news on Phys.org
Apply the adiabatic condition from 3→1.
AM
AM
Can you be more specific? Apply where?
If it's adiabatic there is no heat - I do not understand how the process can be related to thermal efficiency.
What you need is the relationship between P1 and P2 in terms of V1 and V2. That is determined by the adiabatic condition PVγ = K.
AM
AM
Indeed, the ratios match up and allow you to express them with n=γ. Thermodynamics is always like that - an answer under your nose at all times.
But another issue is that the numerator does not match up.
The expected form is r-1 when I get 1-r despite getting the same denominator.
You are using the absolute values of Qh and Qc so you have to make sure that the original equation reflects that. For example, Qc = |Cp(T2-T1)| = Cp(T1-T2)
AM
I need to calculate the amount of water condensed from a DX cooling coil per hour given the size of the expansion coil (the total condensing surface area), the incoming air temperature, the amount of air flow from the fan, the BTU capacity of the compressor and the incoming air humidity. There are lots of condenser calculators around but they all need the air flow and incoming and outgoing humidity and then give a total volume of condensed water but I need more than that. The size of the...
I was watching a Khan Academy video on entropy called: Reconciling thermodynamic and state definitions of entropy. So in the video it says: Let's say I have a container. And in that container, I have gas particles and they're bouncing around like gas particles tend to do, creating some pressure on the container of a certain volume. And let's say I have n particles. Now, each of these particles could be in x different states. Now, if each of them can be in x different states, how many total...
Thread 'Why work is PdV and not (P+dP)dV in an isothermal process?'
Let's say we have a cylinder of volume V1 with a frictionless movable piston and some gas trapped inside with pressure P1 and temperature T1. On top of the piston lay some small pebbles that add weight and essentially create the pressure P1. Also the system is inside a reservoir of water that keeps its temperature constant at T1. The system is in equilibrium at V1, P1, T1. Now let's say i put another very small pebble on top of the piston (0,00001kg) and after some seconds the system...
