Enough information? (WaveLength Question)
  • Thread starter Thread starter quickslant
    Information
AM modulation operates at specific frequencies, with 1 AM corresponding to 1 KHz and 800 AM to 800 KHz. To calculate the wavelength of a radio station broadcasting at 820 AM, one needs to know the frequency, which is 820 KHz. The speed of electromagnetic waves, including radio waves, is approximately 3.0 x 10^8 m/s, which is the speed of light. Using the formula wavelength = speed/frequency, the wavelength can be calculated. Understanding these principles is essential for solving related problems in radio frequency and wave propagation.
quickslant
All it the question says is that AM modulation operates at 1 AM = 1 KHz
and 800 AM = 800 KHz. the questions says to calculate the wavelength of radio station broadcasting at 820 AM
now i know that frequency is 820 KHz but i don't know what velocity it travels at so how do i calculate the wavelength from that
You should know the speed it travels at.
What speed do all electromagnetic waves travel at?
i don't know its not given in the book..
looking it up on the internet it says 3.0 x 10^8 m/s is that correct
yes, that's the speed of light and it's the speed at which all em waves
Thread 'Calculation of Tensile Forces in Piston-Type Water-Lifting Devices at Elevated Locations'
Figure 1 Overall Structure Diagram Figure 2: Top view of the piston when it is cylindrical A circular opening is created at a height of 5 meters above the water surface. Inside this opening is a sleeve-type piston with a cross-sectional area of 1 square meter. The piston is pulled to the right at a constant speed. The pulling force is(Figure 2): F = ρshg = 1000 × 1 × 5 × 10 = 50,000 N. Figure 3: Modifying the structure to incorporate a fixed internal piston When I modify the piston...
