Entertaining review of digital storage oscilloscope
The discussion centers on the Rigol DS2000 series digital storage oscilloscope, specifically the 70 MHz model priced under $1,000, which is being considered for home use. Video reviews of the oscilloscope are highlighted for their entertainment value, particularly for those experienced with oscilloscopes. Key points in the videos include a discussion on the noise floor and a teardown of the scope's construction, though some viewers may find the technical details challenging. There are mixed feelings about the reviewer's enthusiasm, with some appreciating his excitement while others criticize his lack of familiarity with the equipment. Overall, the conversation suggests that while the oscilloscope is appealing, potential buyers should consider higher specifications for more demanding applications.
Redbelly98
Staff Emeritus
Homework Helper
Insights Author
I'm thinking of buying this nice DSO for under 1k $US for home use. It's the 70 MHz model in the Rigol DS2000 series.
But that's not why I'm posting. I wanted to share these video reviews of the scope which are a real hoot -- provided you have spent a lot of your time using oscilloscopes yourself.
The videos are 30-40 minutes each, but even watching for a few minutes is worthwhile.
Here the good stuff starts at about 9:30, where there is a good discussion of the noise floor:
https://www.youtube.com/watch?v=TRy755StMak​
Here he takes the scope apart and reviews the construction and design. I didn't understand half of it, but my background isn't in EE design:
http://www.eevblog.com/2012/09/26/eevblog-360-rigol-ds2000-oscilloscope-teardown/
That guy sure has some enthusiasm. I like how he gets especially excited when he sees heat-shrink tubing :approve:
70 MHz would barely let you view a 10 MHz square wave. Consider getting a better one if you can.
That guy's voice gets higher in pitch as he gets more excited. I wish he would become familiar with the equipment before he demonstrates it.
I saw him pull a photocopier apart. Everything was "amazing" but he had no idea what it all did.
Hey guys. I have a question related to electricity and alternating current. Say an alien fictional society developed electricity, and settled on a standard like 73V AC current at 46 Hz. How would appliances be designed, and what impact would the lower frequency and voltage have on transformers, wiring, TVs, computers, LEDs, motors, and heating, assuming the laws of physics and technology are the same as on Earth?
While I was rolling out a shielded cable, a though came to my mind - what happens to the current flow in the cable if there came a short between the wire and the shield in both ends of the cable? For simplicity, lets assume a 1-wire copper wire wrapped in an aluminum shield. The wire and the shield has the same cross section area. There are insulating material between them, and in both ends there is a short between them. My first thought, the total resistance of the cable would be reduced...
I used to be an HVAC technician. One time I had a service call in which there was no power to the thermostat. The thermostat did not have power because the fuse in the air handler was blown. The fuse in the air handler was blown because there was a low voltage short. The rubber coating on one of the thermostat wires was chewed off by a rodent. The exposed metal in the thermostat wire was touching the metal cabinet of the air handler. This was a low voltage short. This low voltage...
