Solving Enthelpy Problem: ΔH = 12.9 kJ
  • Thread starter Thread starter jools111
The discussion revolves around calculating the enthalpy change (ΔH) for a reaction involving the dilution of NaOH in water. The calculated ΔH value of 12.9 kJ is questioned because it appears positive, while the reaction is exothermic, suggesting it should be negative. It is clarified that the heat absorbed by the solution indicates that the heat was lost by the NaOH, thus necessitating a sign change for ΔH. The correct net ionic equation for the reaction is provided as NaOH → Na+ + OH-. The confusion about changing the sign of ΔH is addressed, confirming that it is appropriate based on the context of heat transfer.
jools111
I am working on a lab that has me a little confused:
I diluted 5.5g of NaOH into 200ml of water to disassociate the sodium ions. In the equation below you can see my temperature results.
Write the net ionic equation for the reaction, and note the value of ΔH.
NaOH ---> Na + OH
ΔH = m•ΔT•Q
ΔH = (200 g + 5.5 g)(final temp - initial temp)(4.18 J/g°C)
ΔH = (205.5 g)(41 °C - 26 °C)(4.18 J/g°C)
ΔH = 12.9 kJ
Because it's an exothermic reaction (It created heat...), I know ΔH should be negative. Why is it coming up positive? I'm lost here... I'm pretty sure I've done everything correctly. Thanks!
Don't worry. You have correctly calculated amount of heat that was absorbed by the solution - it was gained by the solution, so it was 'lost' by the NaOH. Just change the sign.
Beware, correct reaction equation is
NaOH -> Na+ + OH-
you can't ignore ions/charges.
NaOH -> Na+ + OH-
buffer calculator, concentration calculator
pH calculator, stoichiometry calculator
So would the correct answer to the question be negative? I'm a little confused. I understand the logic, but can I just arbitrarily change the symbol like that?
I don't get how to argue it. i can prove: evolution is the ability to adapt, whether it's progression or regression from some point of view, so if evolution is not constant then animal generations couldn`t stay alive for a big amount of time because when climate is changing this generations die. but they dont. so evolution is constant. but its not an argument, right? how to fing arguments when i only prove it.. analytically, i guess it called that (this is indirectly related to biology, im...
