Enthelpy change of an isothermal process
The enthalpy change of an isothermal process is zero for an ideal gas because the temperature remains constant, leading to no change in internal energy (ΔU) and thus no change in enthalpy (ΔH). Although work is done on the system during gas expansion, the relationship ΔH = ΔU + work indicates that the internal energy change is zero. For real gases, the enthalpy change may not be zero due to interactions that deviate from ideal behavior. The equation AM delta H = nC(p)ΔT reinforces that with ΔT being zero, the enthalpy change remains zero. Therefore, in ideal conditions, the enthalpy change in an isothermal process is indeed zero.
sachin123
what is the enthalpy change of an isothermal process?(Why is it 0?)
delta H=delta U+work done on the system(PV work)
For an isthermal expansion of a gas,delta U is 0.Since the gas expands,W is not zero.Then how can delta H be 0?
Δ(pv) isn't pv work, as both pressure and volume are changing. its best to change this to nRΔT. Now its easy to see the because ΔT=0, Δ(pv) is also 0.
It is 0 if you are dealing with an ideal gas but not necessarily for a real gas.
AM
delta H= nC(p)ΔT where C(p) is molar heat capacity at constant pressure. Since in isothermal process ΔT is zero. Thr4 enthalpy change is zero and the term 'pv' is not work. They are pressure and volume of system respectively...
Thread 'Collision of a bullet on a rod-string system: query'
In this question, I have a question. I am NOT trying to solve it, but it is just a conceptual question. Consider the point on the rod, which connects the string and the rod. My question: just before and after the collision, is ANGULAR momentum CONSERVED about this point? Lets call the point which connects the string and rod as P. Why am I asking this? : it is clear from the scenario that the point of concern, which connects the string and the rod, moves in a circular path due to the string...
Thread 'A cylinder connected to a hanged mass'
