Entropy of system with ice cube in lake
The discussion revolves around calculating the entropy change of a system when a 10g ice cube at -10°C is placed in a 15°C lake. Participants emphasize the need to show work for homework-type problems and clarify that the integral used relates to entropy calculations. A user expresses confusion about the integral and its connection to derivatives, specifically asking about the relationship between the integral of dT/T and the natural logarithm. Another participant explains that the focus should be on the integral rather than the derivative, providing insights into the calculus involved. Understanding these concepts is crucial for progressing in physics and thermodynamics.
Brunno
An ice cube of 10g -10°C is placed in a lake that is 15°C.Calcule the variation of entropy of the system when the ice cube to reach the thermal balance with the lake.
The specific heat of the lake is 0,50cal/g°C.:biggrin:
You have to show your work in order to get help on homework type problems here.
What have you tried so far?
Also, next time, please post homework type problems in the appropriate homework help forum.
Ok,GO1,
I'll tell you,You might have thought about my bad English( I'm far way from you).For that,I'm sorry I really don´t write it well.:shy:.But it´s understood what you said!
Well,what have I tried so far?
This:
m*c\int_{Ti}^{T_f}\frac{dT}{T}
But I really don't understand nothing after it.I do know some concepts about derivative,but can you explain the equation above?And it's not a homework,it's just a doubt.
Thank you!
Anyone?
Ok,
Could somebody show me the why the darivative of \frac{dT}{T} is equal to ln\frac{T_f}{T_i}??
Brunno said:
Ok,
It is the integral, not the derivative that you are finding.
HINT:
Start by letting y=ln(x)
Therefore, x=e^y
Take the derivative of both sides and you should be able to solve for dy/dx and derive the result your questioning. Specifically,
\frac{d \ln(x)}{dx}=\frac{1}{x}
So, when finding the this anti-derivative, we have:
\int\frac{dx}{x}=\ln{x} + C
This is a good formula to remember. If you don't remember, or have never learned this, you should probably review your calculus. Not knowing calculus like this will really hinder you as you try to learn more physics.
Thread 'Collision of a bullet on a rod-string system: query'
In this question, I have a question. I am NOT trying to solve it, but it is just a conceptual question. Consider the point on the rod, which connects the string and the rod. My question: just before and after the collision, is ANGULAR momentum CONSERVED about this point? Lets call the point which connects the string and rod as P. Why am I asking this? : it is clear from the scenario that the point of concern, which connects the string and the rod, moves in a circular path due to the string...
