Entropy to never decrease in an isolated system
Entropy in an isolated system is understood to never decrease, but local ordering can occur at the expense of increased entropy elsewhere. Molecules can self-assemble to lower interfacial energy, leading to local decreases in entropy, but this is balanced by greater entropy increases in the surrounding environment. The concept of a closed system must include all interacting particles to accurately assess entropy changes. For instance, when humans consume apples, they create order within themselves while the apple's structure becomes disordered, demonstrating energy transfer and entropy dynamics. Overall, local decreases in entropy do not violate the second law of thermodynamics when considering the entire system.
venomxx
I considered entropy to never decrease in an isolated system, so I am a little confused when i read about how molecules 'self assemble' to lower interfacial energy which leads to an ordering of the system...
Is this ordering not a decrease in entropy violating the law that it always increases?
Im just a little confused, so if anyone can explain this id appreciate it!
Science news on Phys.org
Ordering decreases entropy for the thing that's being ordered, but it increases entropy elsewhere. You have to make sure that your 'closed system' includes ALL interacting particles etc.
Example, humans eat apples to order themselves by destroying the order of the apple. The apple became ordered by using energy from the sun etc.
It's not an isolated system.
I need to calculate the amount of water condensed from a DX cooling coil per hour given the size of the expansion coil (the total condensing surface area), the incoming air temperature, the amount of air flow from the fan, the BTU capacity of the compressor and the incoming air humidity. There are lots of condenser calculators around but they all need the air flow and incoming and outgoing humidity and then give a total volume of condensed water but I need more than that. The size of the...
Thread 'Why work is PdV and not (P+dP)dV in an isothermal process?'
Let's say we have a cylinder of volume V1 with a frictionless movable piston and some gas trapped inside with pressure P1 and temperature T1. On top of the piston lay some small pebbles that add weight and essentially create the pressure P1. Also the system is inside a reservoir of water that keeps its temperature constant at T1. The system is in equilibrium at V1, P1, T1. Now let's say i put another very small pebble on top of the piston (0,00001kg) and after some seconds the system...
