Envelope function for two sine curves
The discussion revolves around finding a generalized envelope function for the sum of two sinusoidal curves with varying amplitudes and periods. The original poster presents two cases with specific parameters and seeks to combine them into a single envelope function that accurately captures the peaks of the combined sine waves.
  • Participants discuss the use of trigonometric identities to simplify the expression for the envelope function. There are inquiries about how to analytically determine the locations of extreme amplitudes from the combined sine curves. Some participants suggest transformations and approximations based on the relationship between the frequencies.
Participants are actively exploring different mathematical approaches and identities to address the problem. There is a recognition of the complexity involved in combining the two cases, and some guidance has been offered regarding the treatment of phase constants and frequency relationships. However, no consensus has been reached on a definitive solution.
The original poster notes that the envelope function derived works only for specific ranges of the parameters and expresses a desire for a more general solution applicable to all combinations of the periods T1 and T2.
kmsiva
Hi,[/B]
I am trying to get an envelope function for two sinusoidal curves (A, B) added up.
a1,a2 are the amplitudes(metre), T1,T2 are the periods (hrs), B lags by dt from A at t=0.
case-1:
a1= 1, a2=0.5, p1=11,p2=10,dt=0
w1=2*pi/T1,w2=2*pi/T2
A = a1*cos(w1*t), B=a2*cos(w2*t+dt)
t varies from 0 to 650 hours
Case-1[/B]
using a envelope function sqrt(a1^2 + a2^2+2*a1*a2*(cos(w2-w1)*t+dt))
i am getting a nice envelope as in the figure 1
Case-2:
a1= 1, a2=0.5, T1=60, T2=10, dt=0
a2 – a1 +2*a1*a2*(cos(w1)*t+dt))
I can manage an envelope as in the figure 2
Is there a way to combine these two conditions ( or any combination of T1 and T2)
so that I can have one generalized envelope function that does not miss the peaks.
Thanks in anticipation for any help
Just a reminder of a trigonometric identity: [itex]\cos(x)+\cos(y)= 2\cos(\frac{x+y}{2})\cos(\frac{x-y}{2})[/itex].
Thanks Svein,
Could you please elaborate little more.
From what ever I have tried out, it works only for a range and not for all combinations of T1 and T2.
I want to identify the location of extreme amplitude analytically from added up sine curves.
I believe the envelope could be represented by a set of sinusoids
sorry if it is something too simple and i am getting lost.
OK. We start out with [itex]A_{1}\cos(\omega_{1} t)+A_{2}\cos(\omega_{2}t+\phi)[/itex]. Assume A1>A2. Then we can transform it into [itex](A_{1}-A_{2})\cos(\omega_{1} t)+A_{2}(\cos(\omega_{1} t)+\cos(\omega_{2}t+\phi))=(A_{1}-A_{2})\cos(\omega_{1} t)+2A_{2}\cos(\frac{\omega_{1}+\omega_{2}+\phi}{2})\cos(\frac{\omega_{1}-\omega_{2}-\phi}{2})[/itex].
In radio technology this shows us that adding an audio signal (ω2) to a carrier wave (ω1) gives us a carrier wave plus two side bands [itex]\frac{\omega_{1}+\omega_{2}+\phi}{2}[/itex] and [itex]\frac{\omega_{1}-\omega_{2}-\phi}{2}[/itex]. You can see this best when ω1>>ω2. In your case (when ω1≈ω2), the result is harder to see.
I don't know how you arrived at the envelope function you posted, so I may be just telling you what you already know here.
First, lose the phase constant. If the two frequencies are different then the phase constant is equivalent to a shift along the time axis, so is not interesting.
I would then apply the identity Svein mentioned, but in a more symmetric manner.
Get F(t) into the form ##C\sin(\bar \omega t)\cos(\hat \omega t)+D\cos(\bar \omega t)\sin(\hat \omega t)## where ##\bar\omega = \frac{\omega_1+\omega_2}2## and ##\hat\omega = \frac{\omega_1-\omega_2}2##. Clearly the ##\bar \omega## factors are the higher frequency of the two, so we want to find the maximum of F over a cycle of that.
If this frequency is much higher than ##\hat \omega##, we can treat the ##\hat \omega## as constant over such a cycle and find the max of F on that basis. This leads to the equation you posted.
If the original frequencies are very different then ##\hat \omega## and ##\bar \omega## will be of similar magnitude, so this method does not work. Instead, you can treat the lower frequency function as roughly constant over a cycle of the higher frequency and arrive at your other equation.
So each solution is just an approximation that works well in its own domain. The worst case, I guess, would be where the ratio of the original frequencies is the same as the ratio of the sum and difference frequencies: ##\omega_1:\omega_2=\bar\omega:\hat\omega##. Try plotting one of those to see if it gives any insight.
  • · Replies 97 ·
17K
