Eotvos effect - Apparent only?
  • Thread starter Thread starter Simple_One
    Coriolis
Simple_One
Hi all,
To get straight to the point of my question, is the Eotvos effect purely an 'apparent' effect?
i.e. it only arises if you choose a biased reference frame that is fixed to the surface of a rotating object (in our case the spinning surface of the earth)?
From my understanding of the article that I read on Wikipedia, it seems like it would only be worth discussing if your frame of reference is on a spinning surface relative to some other absolute coordinate system...is that roughly a valid statement, if not, what is incorrect about that statement?
Somewhat further to that (/as a refinement of the above), is it in any way incorrect to state that the Eotvos effect is actually completely accounted for if you correctly account for the Coriolis Effect? (the latitudinal component of the Coriolis effect in particular?)
...It seems to me that the East-West latitudinal component of the Coriolis effect is really just another way of expressing the Eotvos Effect - or vice versa - when your frame of reference is fixed to a spinning object, all of which is being measured against some fixed coordinate system...
FYI: I ask this question from the context of external ballistics, which is to say that it is related to correcting for the trajectory of a projectile when fired from (and hopefully intercepting) another location on the Earth's surface.
Thanks
Yes, it's the consequence of using a non-inertial reference frame. See also:
http://en.wikipedia.org/wiki/Fictitious_force
No. The Eötvös effect is the vertical (surface normal) component of the total Coriolis effect. In some contexts "Coriolis effect" refers only to the horizontal components, and the vertical is called Eötvös.
If you want to do your ballistic computations in the non-inertial frame of the Earth, but still use Newtons 2nd Law, you have to introduce inertial forces:
http://en.wikipedia.org/wiki/Rotating_reference_frame#Newton.27s_second_law_in_the_two_frames
Note that there is no Eötvös force in the above formulas. It is included in the Coriolis force
Okay, thanks very much for the clarification.
OK, so this has bugged me for a while about the equivalence principle and the black hole information paradox. If black holes "evaporate" via Hawking radiation, then they cannot exist forever. So, from my external perspective, watching the person fall in, they slow down, freeze, and redshift to "nothing," but never cross the event horizon. Does the equivalence principle say my perspective is valid? If it does, is it possible that that person really never crossed the event horizon? The...
From $$0 = \delta(g^{\alpha\mu}g_{\mu\nu}) = g^{\alpha\mu} \delta g_{\mu\nu} + g_{\mu\nu} \delta g^{\alpha\mu}$$ we have $$g^{\alpha\mu} \delta g_{\mu\nu} = -g_{\mu\nu} \delta g^{\alpha\mu} \,\, . $$ Multiply both sides by ##g_{\alpha\beta}## to get $$\delta g_{\beta\nu} = -g_{\alpha\beta} g_{\mu\nu} \delta g^{\alpha\mu} \qquad(*)$$ (This is Dirac's eq. (26.9) in "GTR".) On the other hand, the variation ##\delta g^{\alpha\mu} = \bar{g}^{\alpha\mu} - g^{\alpha\mu}## should be a tensor...
ASSUMPTIONS 1. Two identical clocks A and B in the same inertial frame are stationary relative to each other a fixed distance L apart. Time passes at the same rate for both. 2. Both clocks are able to send/receive light signals and to write/read the send/receive times into signals. 3. The speed of light is anisotropic. METHOD 1. At time t[A1] and time t[B1], clock A sends a light signal to clock B. The clock B time is unknown to A. 2. Clock B receives the signal from A at time t[B2] and...
