Epislon Delta Proof: Limit of a Sequence
b0it0i
prove: lim n-> inifity Sn = 0
Let Sn = (n+1)/(n^2 +1)
(for all epsilon > o) (there exists N) (for all n) [ n>N => |Sn-0| < epsilon]
i let epsilon be arbitrary, so we must show that there exists an N such that for all n [ n>N => |Sn-0| < epsilon
Find N
|Sn -0| = |(n+1)/(n^2 +1)| = (n+1)/(n^2 +1)
I'm completely stuck on this step. I'm not sure how to deal with inequalities where i can make it (some term / n) < epsilon
so I can't choose N= term/epsilon
Any help would be much appreciated
Hint:
\frac{n+1}{n^2+1} &lt; \frac{n+1}{n^2-1}
with that in mind
do i say
n>2
so that 1. n^2 - 1 > 0
2. n+1 < n+n = 2n
n^2 >4
1/4 n^2> 1
-(1/4) n^2 < -1
n^2 -1> n^2 - (1/4) n^2 = (3/4) n^2
1/(n^2-1) < 4/(3n^2)
|Sn|< (2n)/(n^2-1) < (8n)/(6n^2)=4/(3n)
4/(3n) < epsilon
when
n> 4/(3 epsilon)
N = max {2, 4/(3 epsilon)}
b0it0i said:
with that in mind
do i say
4/(3n) < epsilon
when
n> 4/(3 epsilon)
What you have looks ok.
I was actually thinking:
S_n=\frac{n+1}{n^2+1}&lt;\frac{n+1}{n^2-1}=\frac{n+1}{(n+1)(n-1)}=\frac{1}{n-1}
Which leads to
N=\max(2,\frac{1}{\epsilon}+1)
Another good one is:
S_n=\frac{n+1}{n^2+1}\leq\frac{2n}{n^2}=\frac{2}{n}
(The inequality is clearly true since the numerator increases, and the denominator decreases, and both are positive.)
N=\max(1,\frac{2}{\epsilon})
There are two things I don't understand about this problem. First, when finding the nth root of a number, there should in theory be n solutions. However, the formula produces n+1 roots. Here is how. The first root is simply ##\left(r\right)^{\left(\frac{1}{n}\right)}##. Then you multiply this first root by n additional expressions given by the formula, as you go through k=0,1,...n-1. So you end up with n+1 roots, which cannot be correct. Let me illustrate what I mean. For this...
