Epsilon/Delta Proof With 2 Variables
  • Thread starter Thread starter Gooolati
    Proof Variables
Gooolati
Prove:
f(x,y) = \frac{x(x^{2}-y^{2}}{(x^{2}+y^{2}} if (x,y) \neq (0,0)
0 if (x,y) = (0,0)
is continuous at the origin
\forall \epsilon > 0 \exists \delta > 0 s.t. if |(x,y)| < \delta then |f(x,y)| < \epsilon
(Since we are proving continuity at the origin)
|(x,y)| < \delta \Leftrightarrow x^{2} + y^{2} &lt; \delta^{2}
then this means that |x^{2} - y^{2}| < \delta^{2}
so:
f(x,y) < \frac{x}{x^{2}+y^{2}}(\delta^{2})
and I feel like I'm close but then I'm stuck! All help appreciated thanks !
Gooolati said:
Prove:
0 if (x,y) = (0,0)
so:
Have you tried thinking about it in polar coordinates? It's much easier.
hmm I have never used polar coordinates with an epsilon delta proof before
so x=rcosθ
and y=rsin
so f(x,y) is rcosθ(cos^{2}θ - sin^{2}θ)
and r<\delta and cosθ <= 1
so f(x,y) < \delta(cos^{2}θ - sin^{2}θ)
which = \deltacos(2θ) <= \delta(1) = \delta
set \delta = \epsilon
does this work?
so x=rcosθ
and y=rsin
does this work?
Sure does. If r<ε then |f(r,θ)-f(0,0)|<ε.
Isn't that |f(r,θ)-f(0,θ)| < ε ?
Oh, you know what I mean. But I don't see why you'd have to write it that way. f(0,θ)=0 and f(0,0)=0. Same thing. They are both the origin in xy coordinates.
There are two things I don't understand about this problem. First, when finding the nth root of a number, there should in theory be n solutions. However, the formula produces n+1 roots. Here is how. The first root is simply ##\left(r\right)^{\left(\frac{1}{n}\right)}##. Then you multiply this first root by n additional expressions given by the formula, as you go through k=0,1,...n-1. So you end up with n+1 roots, which cannot be correct. Let me illustrate what I mean. For this...
