Eqn for SHM, sin function, so why cos?
The equation for simple harmonic motion can be represented using either a sine or cosine function, as both forms are equivalent. The choice between x(t) = A sin(wt + ∅0) and x(t) = A cos(ωt + φ) is arbitrary and depends on the initial conditions of the motion. A cosine function indicates that the motion starts at maximum displacement, while a sine function indicates that it starts at the equilibrium position. The difference between the two is merely a phase shift of 90 degrees. Both representations effectively describe the same oscillatory behavior.
ZedCar
I had thought the eqn of simple harmonic motion is a sinusoidal function of time, with the eqn being:
Halfway down this page:
http://electron9.phys.utk.edu/phys135d/modules/m9/oscillations.htm
in Problems:
in solution (a) it gives;
The displacement as a function of time is x(t) = Acos(ωt + φ).
Why are they using a cos and not a sin function?
Which one you use is arbitrary. Realize that the only difference between the two is a phase factor. (Shift a sine function by 90° and it becomes a cosine function.)
Using x = Acosωt just implies that you are starting the clock when the object is at its maximum displacement. Using x = Asinωt implies that you are starting the clock when the object passes the equilibrium point.
Just two completely equivalent ways of describing the same thing.
Thank you Doc Al :smile:
Doc Al has said it... you will not hear a more straightforward explanation
Thread 'Collision of a bullet on a rod-string system: query'
In this question, I have a question. I am NOT trying to solve it, but it is just a conceptual question. Consider the point on the rod, which connects the string and the rod. My question: just before and after the collision, is ANGULAR momentum CONSERVED about this point? Lets call the point which connects the string and rod as P. Why am I asking this? : it is clear from the scenario that the point of concern, which connects the string and the rod, moves in a circular path due to the string...
