How Does the Coefficient of Restitution Affect Velocity in Collisions?
  • Thread starter Thread starter bpx95
    Force
The discussion centers on how the coefficient of restitution affects the velocity of an object during collisions. When a box hits a wall, its velocity changes based on the materials involved; it can bounce back at a speed that is a fraction of its initial velocity, depending on the elasticity of the materials. The coefficient of restitution quantifies this elasticity, determining how much kinetic energy is retained or lost in the collision. For programming a physics engine, it's suggested to use a parameter to set the bounce-back speed as a percentage of the initial speed. Real-world experiments can help calibrate these values for more accurate simulations.
bpx95
So, this isn't actually homework, but I figured since it is so low-leveled, it qualifies.
I am a programmer writing a little physics engine, just for fun. So this is all theoretical physics I guess. I have very little physics training above high school physics, so bare with me.
Basically, pretend there is a box flying towards a wall at a certain velocity. When it hits the wall, let's call the velocity it was at when it hit it, v. And since the wall is not moving, the velocity of impact would be v, correct? So, an equal and opposite force acts on the box. So I assumed I would just subtract its current velocity v by that force, also v. But then, that would zero out and it wouldn't bounce back. So, then I thought, well maybe its current velocity gets reset to 0, and THEN we subtract v, ending up with -v. But that seems too strong.. I mean, in real life, if you throw something at a wall, it doesn't bounce back at the velocity that it hit the wall (I tried just a few minutes ago to check).
So what happens to the velocity of an object as it hits another object?
Welcome to Physics Forums :smile:
I have moved your question to the General Physics subforum since it is not homework, or a problem from a textbook.
You seem to have a misconception about what forces are. They are conceptually different than velocity, and cannot be added to or subtracted from velocity. More to the point, the force does not "equal" the velocity v.
It will bounce back (as you're aware already). If the other object is a lot more more massive and at rest, it will bounce back (as you're probably aware already). The speed it has after bouncing can be anything from zero up to the speed it initially had. Just what speed it has depends on how much of the original energy (in the form of kinetic energy) gets converted to heat and/or sound upon colliding. And that depends on the materials the object and wall are made of: a clay ball might stick to the wall (have zero speed after bouncing), whereas a highly elastic ball will bounce back with nearly the same speed it had before.
For a simple programming algorithm, you could just have the speed after the collision be some fraction of the initial speed, depending on how elastic you want the collision to be. Eg., perhaps make it bounce back at 80% of the speed it had initially. You would set that percentage as a parameter in the code.
Collisions in 2D or 3D get tricky, since you have to worry about components of the velocity both normal and parallel to the wall. Not my forte, so I'll just leave it at that.
Redbelly98 has written some useful stuff.
I'd like to add that the energy lost wouldn't necessarily be linearly dependent on the initial kinetic energy, but I suppose a linear dependence would be a first approximation.
Another issue, if this physics engine is being written for a game, the most realistic equation isn't necessarily the one you should go for.
EDIT: I now realize Redbelly98 wasn't proposing using a linear dependence of energy lost on initial energy. He was thinking of a linear dependence of final speed on initial speed. I would personally guess that energy lost goes with initial energy. But that's just a guess, really.
Thanks for the replies, guys!
Firstly, no, this isn't being written for a game. Just playing around with physics, sort of creating a scientific simulation zone, with moderate accuracy.
So you're saying that it is more difficult to accurately measure that force, because it completely depends on the material? So, I can just throw stuff at walls in real life and try to use that to measure how much my virtual objects should bounce back!
Thanks!
Yes, if you're going for realism, that's probably the best way to do it
Exactly!It depends upon the material just like friction.Google Co-efficient of restitution.
So I know that electrons are fundamental, there's no 'material' that makes them up, it's like talking about a colour itself rather than a car or a flower. Now protons and neutrons and quarks and whatever other stuff is there fundamentally, I want someone to kind of teach me these, I have a lot of questions that books might not give the answer in the way I understand. Thanks
I am attempting to use a Raman TruScan with a 785 nm laser to read a material for identification purposes. The material causes too much fluorescence and doesn’t not produce a good signal. However another lab is able to produce a good signal consistently using the same Raman model and sample material. What would be the reason for the different results between instruments?
