Equation Confusion: T Explained | 2π√l/g
  • Thread starter Thread starter Air
    Confusion
The equation T = 2π√(l/g) describes the period of oscillation for a simple pendulum, where T represents the time taken for one complete cycle. In this context, T is indeed time measured in seconds, not tension. The length of the string (l) and the acceleration due to gravity (g) are also key variables in this equation. The discussion clarifies that the period does not depend on the amplitude of the swing, emphasizing that it is solely a function of the string length and gravitational acceleration. Understanding this relationship is crucial for calculating the oscillation time accurately.
Air
I've come across a equation and I don't understand whether T is Time/s or Tension/N. Can someone explain this equation:
T = 2 \pi \sqrt{\frac{l}{g}}
Thanks in advance.
That would be the equation for the simple harmonic motion of a hanging mass on a pendulum.
T denotes the period of oscillation,
l the length of the string on which the mass hangs.
Notice that the period doesn't depend on how "wide" the mass swings.
it is time. In fact period. Put the units for them and calculute the final result.
l : m/s
g: m/s^2
(m/s) / (m/s^2) : s
Isn't Period equal to:
P = \frac{1}{T}
So to calculate time of oscillation, T would need to be made subject.
frequence : 1/s
period : s
P = \frac{1}{T}
No, a "period" is a certain length of time and so has the same units as T (whatever "T" means here). The formula you give is for "frequency"- the number of times the pendulum swings during 1 second and so has units of "1/sec".
Thread 'Trying to understand the logic behind adding vectors with an angle between them'
My initial calculation was to subtract V1 from V2 to show that from the perspective of the second aircraft the first one is -300km/h. So i checked with ChatGPT and it said I cant just subtract them because I have an angle between them. So I dont understand the reasoning of it. Like why should a velocity be dependent on an angle? I was thinking about how it would look like if the planes where parallel to each other, and then how it look like if one is turning away and I dont see it. Since...
