Equation for airtime given velocity?
  • Thread starter Thread starter Toptomcat
    Velocity
To determine the airtime of an object thrown straight up at a given velocity in a vacuum on Earth, the relevant equation is derived from kinematics: 0 = v*t + 1/2at^2, where 'd' is the displacement, 'v' is the initial velocity, 'a' is the acceleration due to gravity (approximately -9.8 m/s²), and 't' is time. For example, if a baseball is thrown upward at 20 m/s, the equation simplifies to 0 = 20t - 4.9t². This leads to a quadratic equation that can be solved for 't' using the quadratic formula or by factoring. The discussion emphasizes understanding the relationship between displacement and time in projectile motion. The final airtime can be calculated by solving the resulting equation for 't'.
Toptomcat
Equation for air time given velocity?
Given a certain velocity going straight up in a vacuum on Earth from y = 0 m, how long does a mass remain in the air? Create an equation.
(So, for example, if you throw a baseball up at 20 m/second, how long will it take for it to fall back to your hand?)
Unsure...d = v*t + 1/2at^2?
I know that this should be really elementary, but I must be really sleep-deprived because I'm just not seeing how to extrapolate it from my standard kinematics equations.
For the record, this isn't the whole question, just the part of a lab I'm hung up on...so please don't think I'm trying to get you guys to do my job for me.
You have the correct equation. Just consider this: the d is a vector. It represents the "displacement," or the straight line distance between the initial and final positions of the mass.
Now assume that the mass falls back to the its initial position. What is d =?
Oh. Okay. So for the sample;
0 = 20*t + 1/2(-9.8)t^2
0 = 20t + -4.9t^2
0 = 20t - -4.9t^2...
...apply Quadratic Formula at this point?
No, it's easier than that. Subtract 20t from both sides. then...
