How Do I Solve This Inelastic Collision Equation?
  • Thread starter Thread starter karis scherer
To solve the inelastic collision equation (45)(4) + (m)(7.6) = (45 + m)(6), first expand the right side to get 180 + 6m. Rearranging the equation leads to 180 + 6m = 180 + 7.6m. Next, isolate "m" by moving all terms involving "m" to one side, resulting in 6m - 7.6m = 0. Finally, solve for "m" to find that m equals 56, confirming the initial answer.
karis scherer
Here is the equation:
(45)(4)+(m)(7.6)=(45+m)(6)
As you can see this is an equation for an inelastic collision problem and i am obviously trying to figure out how to solve for "m"
now i already know that the answer is m=56 but i would like to know how you work it out, every time i try it something goes wrong. :(
Show what you've tried. Then we can give you advice you can use.
You want to collect all terms with "m" to one side. Start by multiplying out the right hand side.
