Equation of the plane, keep getting z=0 but can't be
  • Thread starter Thread starter briteliner
    Plane
briteliner
ok so the problem is to evaluate (triple integral)x^2 dV of the solid tetrahedron with vertices (0,0,0) (1,0,0) (0,1,0) and (1,0,1)
so (triple integral)x^2 dzdydx
i made the x-y plane be the base with 0<x<1 and 0<y<1-x
for the z limits, i know they should be 0 to the plane but i am having trouble getting the equation of the plane. i need to use the points (1,0,0) (0,1,0) and (1,0,1) right?
but when i do the cross products of the two vectors <-1,1,0> and <0,0,-1> i get that the k component is 0. which makes no sense looking at the picture because z is not always zero. what am i doing wrong?
You aren't drawing the right picture. The plane defined by those three points is perpendicular to the x-y plane. I think you want to use (0,0,0), (0,1,0) and (1,0,1) to define the plane that lies above the region in the x-y plane. Try the picture again.
now I'm getting a plane equation of z=x which makes no sense when i integrate
That's correct. But how can that make no sense when you integrate? It's a perfectly reasonable limiting plane. One variable in your integral is a dummy, one is the actual limit.
got it, thanks!
Prove $$\int\limits_0^{\sqrt2/4}\frac{1}{\sqrt{x-x^2}}\arcsin\sqrt{\frac{(x-1)\left(x-1+x\sqrt{9-16x}\right)}{1-2x}} \, \mathrm dx = \frac{\pi^2}{8}.$$ Let $$I = \int\limits_0^{\sqrt 2 / 4}\frac{1}{\sqrt{x-x^2}}\arcsin\sqrt{\frac{(x-1)\left(x-1+x\sqrt{9-16x}\right)}{1-2x}} \, \mathrm dx. \tag{1}$$ The representation integral of ##\arcsin## is $$\arcsin u = \int\limits_{0}^{1} \frac{\mathrm dt}{\sqrt{1-t^2}}, \qquad 0 \leqslant u \leqslant 1.$$ Plugging identity above into ##(1)## with ##u...
