Equilibrium: What Must Be True?
  • Thread starter Thread starter badboyben03
    Equilibrium
For an object in equilibrium, the net force must be zero, indicating that forces are balanced and acceleration is zero. However, this does not imply that all individual forces are equal in magnitude, as they can differ while still resulting in a net force of zero. The force of gravity does not necessarily equal the normal force, as scenarios like a ladder leaning against a wall demonstrate. Additionally, while velocity can be constant, it does not have to be zero; it can remain unchanged at a non-zero value. Overall, understanding equilibrium requires recognizing that certain conditions must be met, but not all proposed statements are universally true.
badboyben03
if an object is in equilibrium, then which of the following must be true?
(i know net force has to be 0, forces are balanced, and acceleration is 0. it doesn't always mean it is at rest. i think there's still one or two more "must be trues" in the list.)
a. all individual forces acting upon the object are equal in magnitude.
b. the net force is 0 N.
c. the force of gravity is equal to the normal force.
d. the forces are balanced.
e. the acceleration is 0 m/s/s
f. the object is at rest
g. the velocity (whether zero or non-zero) is constant.
h. the velocity is changing.
I think A, C, D, G are also true, but I might be wrong
A) if they weren't equal, they wouldn't be in equilbrium
C) is the force of gravity wasn't equal to the normal force, it would fall
G) The velocity has to be either consitant or changing, and its not changing
A is not true. The forces can be different in magnitude, as long as the vector sum is zero. (Think about three forces acting on the body.)
C is not true. There might not even be a normal force. But if there was one, it may not equal the weight. (Consider a ladder leaning against a wall: does the normal force equal the ladder's weight?)
