Equipotential Lines Homework: Calculating Electric Field Strength
The discussion revolves around calculating the strength of an electric field using equipotential lines. Participants are examining how to interpret the graph of equipotential lines and apply the relationship between voltage and distance to find electric field strength.
  • Participants discuss the method of dividing voltage by distance to find electric field strength. There are questions about specific values to use for calculations and how to interpret the equipotential lines correctly.
The discussion includes attempts to clarify the interpretation of the graph and the application of the formula for electric field strength. Some participants express confusion about the values and the graph's reading, while others provide insights into the relationship between equipotential lines and electric fields.
There is mention of a lack of instruction on reading graphs from the original poster's teacher, which may contribute to the confusion in interpreting the equipotential lines.
hrs90
The figure below shows the equipotential lines for a uniformly varying electric field.
[PLAIN]https://wug-s.physics.uiuc.edu/cgi/courses/shell/common/showme.pl?cc/DuPage/Phys1202/fall/homework/Ch-20-Potential/equipotential_lines/equ-lines-1.jpg
A) What is the approximate strength of the electric field at point A?
B) What is the approximate strength of the electric field at point B?
-E=ΔV/Δs (That's what I think...)
I think I have to start off by dividing the voltage by the distance, but besides that I really have no idea on how to start the problem. I'm not just looking for an answer, but if anyone could get me started off I'd appreciate it.
That's exactly what you do, divide the voltage by the distance. For the equipotential of A you seem to go approximately 10 Volts lower for every 2cm of y.
Ok, so would it be 15 divided by 3.50 or 15 divided by 5.70? I tried both these numbers, both turn out to be wrong answers.
Where did you get 15 from?
Point A is located between 10 V and 20 V and it is kinda in the middle. So i tought it would be 15, but now I am totally confused! :/
I don't know how to read these graphs, my teacher never really talked about them.
Oh, yeah, you're just interpreting the graphs wrong. Lines of equipotential show that there would be no work to move a particle along one of the lines. So you can see from these graphs that the lines of equipotential is flat along the x axis, so there's no change ever. Ignore the x. Now, in the y-axis we do get change, and that change varies, so there must be an electric field in the direction of y.
E=-∆V/∆s
so approximate the first point A by looking at the change along the y direction for that region
E=-(10-20)/(4.2-2.2)=5
I'll let you do point B.
Thank you so much man. Now not only I know how to do read the graph, I can do the rest of the homework. :)
14K
9K
