RisingSun361 said:
The book claims that, according to the equivalence principle, acceleration and gravity have the same effects.
This looks like a pop science book, not a scientific textbook or paper. Unfortunately, you can't learn science from pop science books, even if they're written by scientists. This statement is too vague to really tell you what the science says, and can easily be misunderstood to be saying something false.
Here is a more precise statement of the equivalence principle. Consider two people: one is standing in his spaceship, which is far out in empty space, well removed from all other objects, and is accelerating at 1 g. The other is standing in a room on the surface of the Earth. The equivalence principle says that, locally, these two situations are equivalent. This means that, if each of the people makes identical measurements over a short enough interval of space and time, they will get identical results; no local experiment will be able to distinguish the two, or to allow either one to tell for sure that he is in the spaceship or in the room on Earth, rather than vice versa.
Note carefully that the force the person standing in the room on Earth feels is not "gravity". It is the force of the Earth pushing up on his feet. Gravity is not a force in relativity. This is one reason why the statement in the book is too vague; it doesn't tell you what it means by "gravity". And if you give "gravity" its obvious meaning to a lay person, namely "whatever it is that makes rocks fall and keeps the Moon in its orbit around the Earth", then the statement in the book is simply wrong; that "gravity" is
not equivalent to acceleration, as should be evident from the above.
RisingSun361 said:
if gravity slows down time, shouldn't acceleration also slow down time?
"Gravity slows down time" is another of those statements that is too vague to really tell you anything, and which can easily be misunderstood to be saying something false. Again, here is a more precise statement.
Consider two people: one is standing on the surface of the Earth, the other is standing at the top of a tall tower directly above the first. If each of them have sufficiently accurate clocks, and they exchange light signals, they will be able to confirm that the clock of the one at the bottom of the tower is running slower; for example, they can verify that there are fewer ticks of the bottom clock between two successive round-trip light signals than there are ticks of the top clock. This is what is actually meant by the common pop science statement that "gravity slows down time".
And in this sense of the statement, it is
true that "acceleration also slows down time". For example, consider two more people, inside a spaceship far out in space that is accelerating at 1 g. One is at the rear of the ship; the other is at the front. By similar measurements to those the first pair made (exchaging round trip light signals and counting ticks of each one's clock between successive signals), they can verify that the rear clock is running slower than the front clock, and if the length of the ship is the same as the length of the tower, the difference in clock rates will be the same in both cases. (Strictly speaking, the tower has to be short enough compared to the size of the Earth for this to be true to a good approximation.)
However, note carefully that the difference in clock rates in both these cases is
not due to any difference in acceleration; it is purely due to a difference in
position. In the above examples, the acceleration of both clocks is the same. The only difference between them is position. This is why we say that acceleration does not affect clock rates, and why the statement in the book is misleading because it invites you to think otherwise. The correct statement is that
position in a gravitational field, or in an accelerating spaceship, affects clock rates.
