Equivalence Principle: Questions Explained
dubiousraves
Sorry for some probably very basic questions, but here goes.
If gravity equals acceleration, how is the Earth's gravity defined by acceleration?
If an accelerating body distorts spacetime, as described in Einstein's thought experiment about a light beam shined through an accelerating box, how is this equivalent to gravity in terms of what's going on outside the box? Put another way, is an accelerating object's equivalence to gravity only extremely local to the object?
If a large body's distortion of spacetime is propagated by gravitons, as some have theorized, do accelerating bodies also produce gravitons? Einstein's thought experiment suggests to me that the answer is no, because the spacetime distortion seems to be a function of geometry, not force. But then, whence gravitons?
--Thanks for indulging a non-physicist (but a curious one!)
That's not what the equivalence principle says. A better statement of the EP would be something like this: Being at rest in a gravitational field is locally equivalent to being at rest in an accelerating rocket. There is no implication that "gravity equals acceleration" in all respects.
It doesn't.
This thought experiment doesn't say acceleration distorts spacetime. It just says that if the box is accelerating, an observer at rest relative to the box will see a light beam passing through the box "fall" downward. Spacetime is flat throughout; there's no distortion of it.
It isn't.
The EP is local, yes. See above.
The easy answer is no, but the strictly correct answer is "it depends", because some types of accelerations can produce gravitational waves. A rocket accelerating in a straight line does not produce any gravitational waves, but other accelerating objects might.
It doesn't? Sure it does! If Capt Kirk throws lead bricks out the hatch, not only does the Enterprise accelerate, but the third time derivative of the quadrupole moment of the ship + bricks system is nonzero, and in lowest order this quantity is the source of gravitational waves.
OK, so this has bugged me for a while about the equivalence principle and the black hole information paradox. If black holes "evaporate" via Hawking radiation, then they cannot exist forever. So, from my external perspective, watching the person fall in, they slow down, freeze, and redshift to "nothing," but never cross the event horizon. Does the equivalence principle say my perspective is valid? If it does, is it possible that that person really never crossed the event horizon? The...
In this video I can see a person walking around lines of curvature on a sphere with an arrow strapped to his waist. His task is to keep the arrow pointed in the same direction How does he do this ? Does he use a reference point like the stars? (that only move very slowly) If that is how he keeps the arrow pointing in the same direction, is that equivalent to saying that he orients the arrow wrt the 3d space that the sphere is embedded in? So ,although one refers to intrinsic curvature...
ASSUMPTIONS 1. Two identical clocks A and B in the same inertial frame are stationary relative to each other a fixed distance L apart. Time passes at the same rate for both. 2. Both clocks are able to send/receive light signals and to write/read the send/receive times into signals. 3. The speed of light is anisotropic. METHOD 1. At time t[A1] and time t[B1], clock A sends a light signal to clock B. The clock B time is unknown to A. 2. Clock B receives the signal from A at time t[B2] and...
