Equivalent capacitance of an infinite system
The discussion revolves around finding the equivalent capacitance of an infinite capacitor system between two points, a and b. The user has established relationships for charge and potential differences across capacitors but is struggling to progress in their solution. They note that the potential differences can be expressed in terms of previous and subsequent capacitors, leading to a recursive relationship. A hint suggests dividing the circuit to analyze the right-hand portion for equivalent capacitance. The user seeks guidance on how to proceed from their current point of confusion.
Fahamedi
Find the equivalent capacitance of the infinite system between points a and b (see figure).
Where Vi is the potential difference in the number i capacitor.
Q=CV
For number i capacitors we have the relations
Q_i=CV_i and Q'_i=CV'_i
\Rightarrow Q\equiv \sum_{i=0}^{\infty}(Q_i+Q'_i)=C\sum_{i=0}^{\infty}(Vi+V'i)
Now if V is the potential difference V=Va-Vb and we look at the paths in the system,
V_0+V'_0=V ; V_0+V_1+V'_1=V ; ... ; V_0+V_1+V_2+...+V_i+V'_i=V ; ...
From this I found
V'_i=V_{i+1}+V'_{i+1}
\Rightarrow Q=C\sum_{i=0}^{\infty}(V_i+V_{i+1}+V'_{i+1})
And I'm stuck here, I don't know what to do next, or should I do something different?
Hint: Say you divide the circuit into two along the dotted line. What's the equivalent capacitance of the righthand portion?
  • · Replies 16 ·
