Can a jetpack help you escape from a black hole?
In summary, a black hole is a region of space where the escape velocity is greater than the speed of light, making it impossible to escape. A dark star, on the other hand, is an object in Newtonian physics with a surface escape velocity greater than the speed of light. While they may seem similar, they are two different concepts based on different theories of gravity. The Schwarzschild radius, derived from the general theory of relativity, is used to calculate the event horizon of a black hole. However, it is still possible to escape a dark star using a jet pack, but it would ultimately be dragged into the forming singularity.
Geishass
Let's use the classical example of a black hole: A massive planet that has shrunk tremendously, until the escape velocity at its surface is greater than the speed of light.
If you were sitting on the surface of said planet, would it still be possible for you to escape?
Let's say you had a jetpack. The thrust of the jetpack just needs to overcome your weight.
As you are propelled upwards, the gravitational field strength decreases.
If you can sustain jet propulsion, could you eventually escape this "black hole"?
I think you misunderstand the concept of black hole. There is a thing called the "event horizon" which would be farther out than any of the mass that created the black hole and anywhere inside it you cannot escape. In any event, you would have to be a REALLY long way away from a black hole for anything like a jet pack to put you out of the gravity well
I think it was John Tyndall who first proposed the idea of star whose surface escape velocity was greater than the speed of light, he called it a 'dark star'.
The (about to be be) qualified answer to your question is yes, it would be possible to escape a dark star and you needn't ever go faster than the speed of light to do so either. However black holes and dark stars are not synoymous, they live in two very different regimes. The former in Newton's theory of gravity, the latter in Einstein's general theory of relativity. Whilst there's a few superficial simlairities between a dark star and a black hole, the two concepts are actually two very different beasts
For general relativity it is not possible to escape a black hole in general relativity, in fact black holes are usually defined by the impossibilty of escape.
Geishass said:
A dark star?
But I have the freakin' Pearson Conceptual Physics textbook by Paul Hewitt, and he states that a dark star is a black hole.
let's be clear:
A dark star is an object in Newtonian physics whose surface escape velocity is greater than the speed of light.
A black hole is an 'object' in general relativity whose escape velocity is gretaer than c within its event horizon (actually this is a bit of a gross simplification).
A dark star is not synonymous with a black hole.
jcsd said:
let's be clear:
And to the OP: At first glance these appear to be the same thing but the different mathematics between the two theories of gravity lead to very different physical entities.
Is time dilation also infinite at the surface of a dark star?
No because you don't have time dilation in Newtonian physics. Assuming general relativity is correct there are no such things as dark stars, instead you have black holes.
Got it now.
If a black hole is a singularity, why should it have a specific event horizon, and how do you calculate this event horizon based on the black holes mass?
Jimmy said:
The Schwarzschild Radius
[tex]r_\mathrm{s} = \frac{2Gm}{c^2}[/tex]
But why should a black hole have such an event horizon in the first place? What is the derivation for the Schwarzschild radius?
It comes from the GR solution to the Einstein field equations for a spherically symmetric and constant in time gravitational field. Google will tell you more.
John Michell actually: http://en.wikipedia.org/wiki/Dark_star_(Newtonian_mechanics)
As above linked article explains, there is only a slim and indirect way of anything escaping a notional dark star. Not that it matters.
Q-reeus said:
I should'v e remembered, I was reading about it a few days ago.
No it doesn't say that, it's talking about the em radiaition that might be seen from a dark star. What I said is perfectly correct.
One additional point:
Supposing you have a supermassive collapsing ball of matter (e.g. a billion solar masses), with a well defined surface (ignore how it came to exist). Suppose it has a well defined surface and you are standing on it. When it has collapsed enough so that it is inside its event horizon, the density and tidal forces for such a super-massive ball are still quite modest. You could absolutely take off from the surface with a jet pack. However, the massive ball is collapsing steadily, and there is no possibility of stopping its collapse. Further, no matter how powerful your jet pack (even though you can pull away from the surface) you will be drawn in with the collapse and (pretty quickly) be dragged into the forming singularity. If you could magically see the event horizon, you would see it moving away from from the surface as fast as outgoing light, and since you cannot overtake light, you would be ever further inside the event horizon, no matter how you fired your jets.
jcsd said:
Q-reeus: "As above linked article explains, there is only a slim and indirect way of anything escaping a notional dark star. Not that it matters."
OK then. Mind explaining how? It had occurred to me after reading that linked Wiki article that rather than a random boost from some stray exterior particle, a conceivable method of escape might be via a form of 'multi-stage rocket' propulsion. Not any actual rocket, but it could be imagined arranging for a staged multi-fission process. One large particle violently fissions into two at it's apogee, and this then repeats for the remainder part(s) that fly outwards. Hugely unlikely of any practical realization. If you had in mind single or multi-stage rockets, I'd like to know what conceivable fuel would do the trick!
In Newtonian physics light is not a limiting velocity and can't be: Galilean relativity only allows infinite speed as a limiting velocity, else the velocity addition rule must change. Thus, there is a finite, large, acceleration which will allow you to overtake and pass light on the way out of a dark star's pull.
Admittedly I hadn't allowed for an infinite speed in Newtonian picture. So ok large and finite acceleration could do it there, but there is still the big question mark as to how that could be sustained in a self-contained system for long enough. Someone's bound to suggest 'matter/anti-matter annihilation' as propellant, but I'd like to see a worked example!
Simple: The surface gravity of a dark star is inversely proportional to M. Make M large enough, and 1 g thrust, continued long enough, will get you away (and take you beyond the speed of light).
PAllen said:
Simple: The surface gravity of a dark star is inversely proportional to M. Make M large enough, and 1 G thrust, continued long enough, will get you away (and take you beyond the speed of light).
Maybe not so simple. Agreed G can be made arbitrarily small, but the problem again is the total energy needed to achieve escape. We are asssuming a fully self-contained system - rocket = payload + propellant. At a stab I'd say minimum theoretical configuration would be that hypothetical 'matter/anti-matter annihilator engine'. Just not sure off-hand if a single-stage design could do the trick. Any rocket scientists on-board? :biggrin:
Everything is still governed by Newonian gravity. The potential energy difference from any r>0, for any M, to infinity, is finite. Now if you want to propose the Newtonian physics is bound by 'energy has mass' and the E=mc^2 equivalence (which all, obviously, comes from relativity), then it still happens to be no problem (if I haven't screwed up a factor): the energy needed to take a mass m from the dark star surface (at critical radius) to infinity is mc^2/2 - so you can do it. You just need to convert half the mass to energy.
PAllen said:
Everything is still governed by Newonian gravity. The potential energy difference from any r>0, for any M, to infinity, is finite. Now if you want to propose the Newtonian physics is bound by 'energy has mass' and the E=mc^2 equivalence (which all, obviously, comes from relativity),...
Without that assumption a matter/anti-matter annihilator (one's only hope of get-away) could not be proposed in the first place, so yes.
...the it still happens to be true (if I haven't screwed up a factor), the energy needed to take a mass m from the dark star surface (at critical radius) to infinity is mc^2/2 - so you can do it. You just need to convert half the mass to energy.
I'd have to check that over, but am assuming that factors in the continual variation in mass enroute. Do you btw allow that said matter/anti-matter annhilator is a photon exhaust engine which is highly inefficient at lower velocities? Most of the propellant power is lost in the v<<c regime as useless 'photon exhaust fumes'. I suspect your calculation would be valid only in the case of our 'rocket' actually being a shuttle-bus on hypothetically infinitely strong rails that extend from critical surface up to - you know - infinity! To be honest I suspect 'realistic' detailed cals actually get quite involved, so I may just say 'maybe' and leave this fairyland hypothetical to wither as it should.
I think the whole discussion is silly. In Newtonian physics, energy had no mass, and there was no mass/energy relation. No law would be violated by positing any energy at all in some imaginary fuel of small mass. The foundation of mass/energy equivalence (SR) is fundamentally inconsistent with Newtonian gravity and Galilean relativity. So you can make up whatever rules you want and get whatever result you want - it is just nonsense.
I was just making a trivial calculation of (Newtonian) potential difference for a mass m between critical radius and infinity.
Couldn't agree more - and that's a rare, rare thing for me! :smile:
Related to Can a jetpack help you escape from a black hole?
1. How do black holes form?
Black holes form when a massive star dies and collapses under its own gravity, causing an intense gravitational pull that even light cannot escape.
2. Is it possible to escape from a black hole?
According to current scientific understanding, it is not possible to escape from a black hole once you are inside its event horizon, which is the point of no return. The extreme gravitational pull would not allow any object, including light, to escape.
3. Can anything survive falling into a black hole?
No, it is believed that anything that falls into a black hole would be crushed into a singularity, a point of infinite density and zero volume, and would not be able to survive.
4. Can black holes be used for time travel?
There is currently no scientific evidence to suggest that black holes can be used for time travel. Although, according to Einstein's theory of relativity, time near a black hole can be distorted, making it appear to move slower or faster for an outside observer.
5. Is there a way to escape from a black hole using a wormhole?
There is no evidence to suggest that wormholes exist, and even if they did, the intense gravitational pull of a black hole would likely cause them to collapse. Therefore, it is highly unlikely that a wormhole could be used to escape from a black hole.
  • Beyond the Standard Models
