Essentials of Calculus: find the limit problem
  • Thread starter Thread starter Nawz
    Calculus Limit
Nawz
SYNTHESIS
Find limit as x approaches 3 of : (x^3-27)/x-3
I typed it into my calculator and got x^3 - (27)/(x-3) where x^3 wasn't divided by x-3. I really do not know where to start. I know the answer is 27 from the back of the book.
I was thinking it was something like x^3- (3)^3/ (x-3) and then you can cancel out one of the x-3 but I still cannot get 27 and if you plugin 3 into the original equation you get 0.
Try factoring x3-27
You need to know that (a- b)(a^2- ab+ b^2)= a^3- b^3.
Or, if you ever forget that a³ - b³ = (whatever it actually equals :-p )
It looks like something that can be factored.
Set x³ - 27 equal to zero.
x³ - 27 = 0
Find an x value that makes x³ - 27 = 0 hold, i.e. x = 3
(3)³ - 27 = 0
Then, because x = 3 is an answer, x - 3 = 0 is a factor so divide x - 3 into x³ - 27
______x²_+_..._______​
x - 3 |x³ + 0x² + 0x - 27
x³ - 3x²​
Keep going & you'll factor it & get your answer :wink:
Or failing that L'Hopital's rule...
Mat
Or use a substitution with u = x - 3, no factoring cubes or l'Hôpital's rule. :wink:
Prove $$\int\limits_0^{\sqrt2/4}\frac{1}{\sqrt{x-x^2}}\arcsin\sqrt{\frac{(x-1)\left(x-1+x\sqrt{9-16x}\right)}{1-2x}} \, \mathrm dx = \frac{\pi^2}{8}.$$ Let $$I = \int\limits_0^{\sqrt 2 / 4}\frac{1}{\sqrt{x-x^2}}\arcsin\sqrt{\frac{(x-1)\left(x-1+x\sqrt{9-16x}\right)}{1-2x}} \, \mathrm dx. \tag{1}$$ The representation integral of ##\arcsin## is $$\arcsin u = \int\limits_{0}^{1} \frac{\mathrm dt}{\sqrt{1-t^2}}, \qquad 0 \leqslant u \leqslant 1.$$ Plugging identity above into ##(1)## with ##u...
