Estimate diffraction angle - homemade spectrometer
The discussion revolves around estimating the diffraction angle using a homemade spectrometer made from a cardboard tube, duct tape, and a diffraction grating. The user observes multiple spectra while looking through the device, raising questions about the accuracy of their slit width and wavelength estimates. They reference the equation ΔΘ=2λ/b, noting that their estimates may be imprecise due to the variability in measurements. Other participants express skepticism about the observation pattern and the proper usage of the spectrometer. Overall, the conversation highlights the challenges of DIY spectrometry and the importance of accurate measurements in diffraction experiments.
Jon.G
Estimate the diffraction angle.
The spectrometer is made from rolling up a 30cm long piece of cardboard into a tube. Duct tape is placed over one end, and a thin slit is made. The other end has a diffraction grating held in place.
I look through the diffraction grating and can see the slit and 8 spectra, going away from the slit. (as if there's one at each corner and halfway along each side of a square)
ΔΘ=2λ/b for b>>λ
b is slit width
I'm not sure if there's another way to do this.
Using this equation, I'd just be taking estimates that could be way off for the slit width and the wavelength (just using white light).
But then the task does say to estimate, so it could be ok.
Thanks for your time.
If your diffraction grating has slits, I don't see how you get the pattern you described.
Are you sure that you looking through the tube is the intended way to use the spectrometer?
Does your spectrometer look something like the one described here ?
Thread 'Collision of a bullet on a rod-string system: query'
In this question, I have a question. I am NOT trying to solve it, but it is just a conceptual question. Consider the point on the rod, which connects the string and the rod. My question: just before and after the collision, is ANGULAR momentum CONSERVED about this point? Lets call the point which connects the string and rod as P. Why am I asking this? : it is clear from the scenario that the point of concern, which connects the string and the rod, moves in a circular path due to the string...
