Does the Shape and Material Density Affect Capacitance in Homemade Capacitors?
In summary: If you have two 5" cubes of aluminum foil that are the same shape and size, then the capacitance will be the same.
jena
74
Hi,
My question: A homemade capacitor is assembled by placing two 9-in pie pans 5cm apart and connecting them to the opposite terminals of 9-V batter. Estimate the capacitance?
I know that to get the capacitance, you can use C=Q/V or C=keA/d. Do I need to find the area of the two pie pans to be help me solve the problem or do I make a triangle and find the area of that.
Thank You
:smile:
Since C=Q/V, unless one knows Q, then one will have to use C=keA/d.
I think one can determine the area of a 9-in pie pan. Perhaps assume a circular pie-pan, i.e. 9-in dia.
Hi,
Work
C=keA/d
C=(8085 x 10^-12)(4.104 x 10^-2)/(5 x 10^-2)
C= 7.26 x 10 ^-12
Okay, I see
Thank You
Is C the charge? or Capacitance? Is it C = Q/ deltaV ?
If you used pie pans, could they be filled with something to change the capacitance? like water?
Is the capacitance value increased as the distance gets smaller between the plates?
Brad, C is the Capacitance, Q is the charge.
Putting a material between the conductive plates (some nonconducting (i.e. insulator) dielectric) will affect the capacitance.
C=keA/d indicates that capacitance increases with increasing area and or decreasing distance.
Okay, let's say you have two 5" square sheets of aluminum foil, and put regular paper in between, glue all three items together. The paper is just over 5" sq like 5.1" sq so the foil won't short out. That setup has some capacitance, C.
Then you have two 5" square, well cubed blocks of aluminum, and put the same 5.1" paper between them. The distance is the same (assume no crushing of paper).
Is the capacitance different? What "electrically" would be different?
With more surface area (including the sides), the capacitance of the blocks should be greater than that of the thin foil - given the same square surfaces.
For a given total charge - the surface charge density would be lower with more surface area.
I can see how the surface charge would be spread out, more surface area means less density, because... (?) the electric charge is always conserved?
Okay but is it all about just surface area? isn't there penetration into all of the atoms in a 5" cube of aluminum? It seems a sheet of foil would be sheets of atoms stacked to some thickness of a few mils or whatever thickness foil is, and I thought the charge filled the entire foil more or less evenly because Aluminum is a conductor.
So if there was a 5" cube of Al, it seems the charge would also distribute evenly.
But there is just the one surface where its facing the other cube, separated by the paper so because of..? the dipole effect? the charge would not be uniform in the cube, but it seems the capacitance must be affected by density of material, because more charge could build up in a cube than foil alone.
would a 5" cube of foil, where the foil was shaped into cube form but empty on the inside, cause the same capacitance as a solid 5" cube of Aluminum?
1. What is capacitance?
Capacitance is a measure of an object's ability to store electrical charge. It is represented by the letter C and is measured in farads (F).
2. How can I estimate the capacitance of an object?
Capacitance can be estimated by using the formula C = Q/V, where C is capacitance, Q is charge, and V is voltage. You can also use a capacitance meter to directly measure the capacitance of an object.
3. What factors affect the capacitance of an object?
The capacitance of an object is affected by its size, shape, and material. Capacitance increases with larger surface area, closer spacing between plates, and higher permittivity of the material.
4. Can the capacitance of an object change?
Yes, the capacitance of an object can change. It can be altered by changing the distance between plates, changing the dielectric material between the plates, or by adding or removing charge.
5. Why is capacitance an important concept in electronics?
Capacitance is important in electronics because it allows for the storage and release of electrical energy, which is essential for many electronic devices. It also plays a role in filtering and regulating electrical signals.
