Estimate the mass of a spinning ice skater
To estimate the mass of a spinning ice skater, one can use the conservation of angular momentum, applying the equation I1ω1=I2ω2. A crude model of the skater can be created using geometric shapes, such as cylinders for the torso and arms, with their mass moments of inertia calculated accordingly. When the arms are folded, their mass is added to the torso, and the parallel axis theorem may be needed for accurate calculations. To derive the torso and arm masses, the expressions for the moments of inertia should be detailed, and data from the skater's rotation can be applied. Assuming the arms' mass as a fraction of the torso's mass simplifies the problem to a single variable for easier calculation.
spiruel
If you have data such as time of rotation when arms are extended and the lengths of their folded and extended arms measured from the centre of the skater.
I know I1ω1=I2ω2 and can work out ω from the radius and time of rotation. Where can I go from here to estimate the mass?
Thanks
I_1\omega_1=I_2\omega_2
\omega = \frac{2\pi}{T}
Create a crude model of the skater using simple geometric shapes for which you know (or can look up) the mass moment of inertia about various axes. For example, make the torso a cylinder of uniform density, the arms two more cylinders when outstretched. Estimate what you think might be reasonable geometry for them (length, diameter). When the arms are folded in, the arm cylinders just add their mass to the torso cylinder and otherwise disappear. You may need to use the parallel axis theorem to get the right center of rotation for your "arms".
The unknowns will be the mass of the torso cyclinder and the mass of an arm.
Thank you for the reply.
Would the expressions below be along the right lines?
I_{in} = \frac{1}{2}*M_{torso}*r_{torso}^2 + m_{arms}*(r_{torso}+r_{folded arms})^2
I_{out} = \frac{1}{2}*M_{torso}*r_{torso}^2 + m_{arms}*(r_{torso}+r_{outstretched arms})^2
That's the idea. You'll want to show in detail how you arrived at the expressions for the arms, the outstretched arms in particular. Check the mass moment of inertia for a cylinder rotating about an axis that is not parallel to its central axis (for example, suppose it were rotating about one end).
Thank you for the help so far.
How would I go about using the above expressions to obtain a result for the torso mass and arm masses together?
Presumably you'll apply your data and conservation of angular momentum to arrive at an equation for which you can solve for the mass. Another hint: It might be worthwhile assuming that the mass of the arms is some fraction of the mass of the torso, so you'll have only one mass variable to deal with.
Thread 'Collision of a bullet on a rod-string system: query'
In this question, I have a question. I am NOT trying to solve it, but it is just a conceptual question. Consider the point on the rod, which connects the string and the rod. My question: just before and after the collision, is ANGULAR momentum CONSERVED about this point? Lets call the point which connects the string and rod as P. Why am I asking this? : it is clear from the scenario that the point of concern, which connects the string and the rod, moves in a circular path due to the string...
Thread 'A cylinder connected to a hanged mass'
