Estimate the uncertainty in electron's position.
To estimate the uncertainty in an electron's position given its speed range of 6.0×10^6 m/s to 6.7×10^6 m/s, the uncertainty in momentum is calculated using the equation ΔpΔx ≥ h/2π. The attempt at a solution yielded a position uncertainty of approximately 0.00000000016546 m, but this was marked incorrect. Participants in the discussion noted that the velocity range used was appropriate, yet the calculated result did not align with expected answers. The conversation highlights confusion over the accuracy of the calculations and the criteria for correctness in the problem.
Steelers72
1. Question
The speed of an electron is known to be between 6.0×10^6 m/s and 6.7×10^6 m/s . Estimate the uncertainty in its position.
ΔpΔx ≥ h/2π
(mΔv) Δx ≥ h/2π (Since Δp= mΔv)
Δx≥ h/2π(mΔv)
h= 6.63*10-34 J*s
c= 3.0*108
mass of electron= 9.11*10-31
(6.63*10^-34)/(2pi(9.11*10^-31)*(6.7*10^6 - (6*10^6))
= 0.00000000016546 m
Apparently this is incorrect. What am I doing wrong?
The range of velocities in that picture is different from the one in your problem.
I am aware, that is why I wrote my work in the 3rd step of the post. I used my own velocity range.
Why is it not correct? Using your own velocities, I also got the same value. Do I miss something about what you actually want to figure out?
I'm not sure. My answer was marked incorrect which is strange. I understand the problem and how to do it. I figured maybe my work was wrong or a small error?
Thread 'Collision of a bullet on a rod-string system: query'
In this question, I have a question. I am NOT trying to solve it, but it is just a conceptual question. Consider the point on the rod, which connects the string and the rod. My question: just before and after the collision, is ANGULAR momentum CONSERVED about this point? Lets call the point which connects the string and rod as P. Why am I asking this? : it is clear from the scenario that the point of concern, which connects the string and the rod, moves in a circular path due to the string...
Thread 'A cylinder connected to a hanged mass'
