Estimating internal (junction) temperature
The discussion focuses on estimating internal junction temperature (Tj) in a motion sensor housed in a sealed metal enclosure. The user calibrates the device using an external temperature sensor but faces challenges during rapid temperature changes, particularly in the first five minutes after powering up. The significant temperature gradient between the case temperature (Tcase) and internal temperature (Tj) leads to inaccurate offset compensation. The user seeks a straightforward method to estimate Tj, assuming equal temperatures at startup. They also inquire about available online resources for further information on this topic.
Eli Hait
Hello.
I use a kind of motion sensor located in a sealed metal enclosure.
I perform temperature offset calibrating to this device, using an external temperature sensor (attached to the enclosure). This solves the most of temperature problems except when the temperature gradient is large - for instance for 1'st 5 minutes afrer powering the device.
After checking this issue my conclusion was that in fast temperature gradients the temperature delta between the case temperature (Tcase, the one i measure) and internal (Tj) temperature is too large so i don't compensate the real offset error.
My question is if there is a simple method to estimate the internal temperature (Tj), if at the beginning (before powering up the sensor) the external and internal temperatures are equal Tcase=Tj.
Is there good information about it on the web?
Thanx,
Eli.
someone... please...
I used to be an HVAC technician. One time I had a service call in which there was no power to the thermostat. The thermostat did not have power because the fuse in the air handler was blown. The fuse in the air handler was blown because there was a low voltage short. The rubber coating on one of the thermostat wires was chewed off by a rodent. The exposed metal in the thermostat wire was touching the metal cabinet of the air handler. This was a low voltage short. This low voltage...
Thread 'How Does Jaguar's 1980s V12 Dual Coil Ignition System Enhance Spark Strength?'
I have come across a dual coil ignition system as used by Jaguar on their V12 in the 1980's. It uses two ignition coils with their primary windings wired in parallel. The primary coil has its secondary winding wired to the distributor and then to the spark plugs as is standard practice. However, the auxiliary coil has it secondary winding output sealed off. The purpose of the system was to provide a stronger spark to the plugs, always a difficult task with the very short dwell time of a...
