Exercise bike that produces electricity
The discussion centers on the concept of an exercise bike that generates electricity, exploring its feasibility and design considerations. A DC generator is recommended for charging batteries directly, while AC generators require precise pedaling speeds to function effectively. The output power from a cyclist is limited, with estimates suggesting a good cyclist can produce about 200 watts for an hour, which translates to minimal electricity generation. Lead-acid batteries are suggested for storage due to their reliability and cost-effectiveness. The conversation also highlights that while gear systems can increase generator speed, they cannot produce more energy than is input, emphasizing the conservation of energy principle.
fellupahill
Ok.
Folks, first off this is my first post, and I am looking for some answers to some questions I have. I hope someone has the time to answer them :)
First off, I'm no expert in physics. I know a billion times more than any of my friends but believe me that is not saying much. I have never really studied it in an academic atmosphere, I have only read several books for laymen, QED, Brief history of time, a couple more hawkings papers, schordingers cat (spelling) and a few others. Just enough to blow my mind.
Anyway, I have a long story that I won't bother you guys with that explains how I came up with the idea for a Exercise bike that produces electricity, and then either offers the consumer the option to plug right into an AC outlet or to store it in a battery.
I have some questions that i need answered before I start looking on how to design it.
1. If I were to say use a normal Generator, say like the ones wind turbines use, what kind of current would that produce? AC or DC?
2. A motion specific physics question. http://askalexia.com/2009/02/06/cylec-exercise-bike-generates-electricity-to-charge-your-gadgets/"
This is the only working prototype that is currently even close to being production value. And I notice the Electrical output is minimal. It takes 2 hours to charge a battery that will power a fan for 3 hours. What would be a system that would maximize the effort used to make the electricity. I was thinking about how a gear system works. Would there be a way to get the bike to were you peddle less and turns the generator faster?
3. What would be the right battery to use. Obviously in America all the power is AC, are standard rechargeable battery's put out AC or DC current?
Also any other things I need to look at?
I am not familiar with wiring or circuitry so any resources would be great.
Not too difficult - has been done as a joke/toy - so you can only have the TV on if you are prepared to exercise
Generally you would use DC. A dc generator can charge a battery directly.
An AC generator can in theory run an appliance directly BUT the frequency depends on the speed, so would have to peddle at exactly the correct speed to generate 50/60Hz AC (depending on your country)
A safer way is to generate DC, charge a battery and have an inverter, like the ones used to run a laptop in your car, to generate the 110/220V AC
Connecting into the grid (ie sending power back to the electric company) is more difficult. You can do it (in most areas) but you need some fancy expensive electronics to convert your power into exactly what the company wants (voltage, frequency, phase) - it's just an upmarket version of the inverter but costs $2000-$5000
Probably not worth it for the amount of power you can generate !
Fundamentally it all comes down to power. A good team cyclist can sustain about 1/4horse power for an hour - that's 200Watts * 1 hour = 0.2kw-hours or 1/5 of a unit of electricity.
That costs about 2c in the USA but would take around 2000calories (or 10 Snickers bars) to generate
Normally home power systems (solar or wind) use lead acid batteries because it is cheap easy and reliable
Search for "off-grid, wind power, solar" - there were a couple of good google tech talks on youtube also mentioned here
mgb_phys said:
Not too difficult - has been done as a joke/toy - so you can only have the TV on if you are prepared to exercise Generally you would use DC. A dc generator can charge a battery directly.
Probably not worth it for the amount of power you can generate !Fundamentally it all comes down to power. A good team cyclist can sustain about 1/4horse power for an hour - that's 200Watts * 1 hour = 0.2kw-hours or 1/5 of a unit of electricity.
That costs about 2c in the USA but would take around 2000calories (or 10 Snickers bars) to generateNormally home power systems (solar or wind) use lead acid batteries because it is cheap easy and reliable
Ok.
So increasing say the wheel size to spin the turbine more times around than if normal, or is there a way with momentum to increase the output?
I was also thinking about those really old workout bikes that turned fans and the handlebars moved too. the fan gets going way faster than the rider id pedaling. Could this help me at all?
No you can't get more energy out than you put in.
You can spin a generator/fan faster, but with less force - it all cancels out (except that you lose energy in the gears)
This is from Griffiths' Electrodynamics, 3rd edition, page 352. I am trying to calculate the divergence of the Maxwell stress tensor. The tensor is given as ##T_{ij} =\epsilon_0 (E_iE_j-\frac 1 2 \delta_{ij} E^2)+\frac 1 {\mu_0}(B_iB_j-\frac 1 2 \delta_{ij} B^2)##. To make things easier, I just want to focus on the part with the electrical field, i.e. I want to find the divergence of ##E_{ij}=E_iE_j-\frac 1 2 \delta_{ij}E^2##. In matrix form, this tensor should look like this...
Thread 'Applying the Gauss (1835) formula for force between 2 parallel DC currents'
Please can anyone either:- (1) point me to a derivation of the perpendicular force (Fy) between two very long parallel wires carrying steady currents utilising the formula of Gauss for the force F along the line r between 2 charges? Or alternatively (2) point out where I have gone wrong in my method? I am having problems with calculating the direction and magnitude of the force as expected from modern (Biot-Savart-Maxwell-Lorentz) formula. Here is my method and results so far:- This...
