Exist Devices to Assist in Exerting 160+ Lbs of Force?
The discussion revolves around the existence of devices that can assist in exerting a force of 160 lbs or more, particularly in a manner that allows for minimal effort from the user, such as moving arms in a flapping motion. The focus includes exploring various mechanical systems that could achieve this force application.
  • One participant inquires about devices that can assist in exerting a force of 160 lbs or more while minimizing user effort, specifically through arm movements.
  • Another participant suggests linear actuators, hydraulic ram systems, or screw jacks as potential solutions.
  • A different participant proposes the use of a lever as a means to achieve the desired force application.
  • Further discussion includes the idea that with sufficient leverage and appropriate materials, a lever could theoretically lift any weight.
Participants present multiple competing views on the types of devices that could assist in exerting the required force, with no consensus on a single solution or approach.
Participants have not provided detailed specifications or limitations regarding the devices mentioned, and the discussion lacks concrete examples or empirical evidence to support the proposed solutions.
socalfusions
Do any devices exist that can assist your arms in exerting a force of 160 lbs or more in a direction of such where you would have your arms extended and move them up and down, like flapping wings for example, to the effect that you would be using the minimum amount of effort required which would be you just moving your arms and not actually have to support the required weight?
In another post I made about what devices could help in exerting a force of 160 lbs or greater someone mentioned linear actuators, which looked very promising, but I haven't come across solid enough information of whether they could obtain what I am looking for.
Perhaps my more detailed explanation in this thread will be more helpful in determining whether such technology exists, thanks in advance.
Linear actuators, some form of hydraulic ram system or a screw jack.
That's the best I can come up with.
Thanks I'll try to do some more research on these suggestions.
russ_watters said:
A lever.
Can you elaborate some more please? :-p
A big lever?
But seriously, with enough leverage, providing the lever material is up to it, you can lift anything.
  • · Replies 19 ·
  • · Replies 17 ·
