Expand in more localized than Fourier
  • Thread starter Thread starter Gerenuk
    Fourier
The discussion explores the possibility of expanding a function f(x) using a periodic function g that is not necessarily exponential. It highlights that if g is periodic, it can be represented by a Fourier series, which typically involves sums of exponential functions. The conversation raises questions about the uniqueness of the expansion and the need for a back transformation. It suggests that if g is a combination of exponentials, it may not yield alternative solutions beyond the standard Fourier transform. Overall, the thread delves into the complexities of function expansion in relation to periodicity and uniqueness.
Gerenuk
Can I expand a function in
f(x)=\sum_k g_k(x\cdot k)
where g is a periodic function that is not an exponential?
So
g_k(a)=g_k(a+1)
What if there doesn't necessarily have to be a back transformation or if the expansion doesn't have to be unique?
Mathematics news on Phys.org
If g is a periodic function, then you can represent it with a Fourier series. So if g is not an exponential, it is a (most likely infinite) sum of exponentials.
So can I find a function for g? I thought if g is a combination of exponentials, then there won't be another solution rather than the usual Fourier transform?
Suppose ,instead of the usual x,y coordinate system with an I basis vector along the x -axis and a corresponding j basis vector along the y-axis we instead have a different pair of basis vectors ,call them e and f along their respective axes. I have seen that this is an important subject in maths My question is what physical applications does such a model apply to? I am asking here because I have devoted quite a lot of time in the past to understanding convectors and the dual...
Insights auto threads is broken atm, so I'm manually creating these for new Insight articles. In Dirac’s Principles of Quantum Mechanics published in 1930 he introduced a “convenient notation” he referred to as a “delta function” which he treated as a continuum analog to the discrete Kronecker delta. The Kronecker delta is simply the indexed components of the identity operator in matrix algebra Source: https://www.physicsforums.com/insights/what-exactly-is-diracs-delta-function/ by...
