Expanding 2^(ab)-1 to the Mersenne Number Theorem
  • Thread starter Thread starter Joseph1739
    Expanding
20 replies · 9K views
Joseph1739
I'm trying to understand a proof for Mersenne number theorem, but I'm having trouble understanding the expansion from 2ab-1 into (2a-1)((2a)b-1+(2a)b-2+...+2a+1)).
Not sure
I don't know where to start really and I can't seem to find any proof that explains what is going on in this step.
on Phys.org
Not sure
They are factoring ##2^{ab} - 1## into the two factors you show. Note that ##(a^m)^n = a^{mn}##.
Sorry, I forgot to include that part. I understand that (am)n = amn. I don't see how see how (2a)b-1 helps with factoring this though. To be honest, before I saw this proof, I thought there were no other ways to factor it. Is there some factoring rule that I am missing?
It's not a rule that you would learn in an algebra class, I don't believe. Try it out with some specific numbers. For example, with a = 3 and b = 2, you have ##2^6 - 1 = (2^3 - 1)(2^3 + 1)##.
With a = 3 and b = 3, you have ##2^9 - 1 = (2^3 - 1)(2^6 + 2^3 + 1)##
I was trying it out with (22)3 and it simplifies to the same result. I just really wanted to know how that equivalence was derived.
Look at the formula for summing a geometric series.
Would that make it: ((2ab(1-2ab)/(1-2)) -1 = -22ab -1 ? Am I doing something wrong here? Ignoring the -1 right now, the first term is 2ab, n = ab, and the common ratio is 2.
Not sure
Have you ever seen the expansion
[tex]x^n - 1= (x-1)(1+x+x^2+ \cdots x^{n-1})[/tex]
for any ##x## and positive integer ##n##? Just apply it to ##x = 2^a## and ##n = b##, provided that ##b## is a positive integer.
I don't know how that expansion is derived. I understand how to get expression on the right side by dividing the original polynomial by (x-1), but I don't know how (x-1) was factored with begin with.
Sorry, I assumed everybody had seen that result before, as it is a part of elementary algebra. You can derive it from the formula for the sum
[tex]1 + x + x^2 + \cdots + x^k[/tex]
Google 'geometric series'.
Would't that result in = 1(1-xk)/(1-x) = (1-x)k-1?
No.
Anyway, why would you think that ##(1-x^k)/(1-x) = (1-x)^{k-1}##? That is false. Try it for yourself: put ##x = 1/2## and ##k = 3## into both sides and see what happens.
Have you done what I suggested (Google 'geometric series')?
It looks like you know everything but don't know your know it.
You know how to get from left to right and right to left.
If the question is how did anyone hit on the fact (x - 1) is a factor of (x n - 1) without someone telling them, or the examples, they could have noticedn that x = 1 makes (x nn - 1) be 0 and after a bit they said
And you should have met it in another form, see #6, though not always the relation is pointed out.
Yeah, I did google geometric series. I looked at the sum of geometric series formula when the other guy posted about it. And I got:
1 = first element
x = common ratio
k = nth element
1 = first element
x = common ratio
k = nth element
And what formula did they give you for the finite sum?
That makes sense, but how does 2a-1 factor out of (2a)b-1? 2 raised to a power minus 1 will not be zero anymore unless the exponent is 0.
(a1)(1-rn/1-r) = (1)(1-xk/1-x) = (1-xk)/(1-x)
:oldtongue:Re #16 Just look at formula in #8 for instance.
2a is x and b is n.b
Note that since 2ab = (2a)b = (2b)a you can get another valid formula just exchanging a with b everywhere, there is nothing to distinguish between a and b algebraically, though extra-mathematically you might have decided on them standing for particular different things.
But maybe the question was a different one: you did not realize that nothing was being raised to power -1: the guy was just using correct notation (for a subtraction of 1 from (2a)b) which a lot of people don't bother with here. :oldtongue:
2a is x and b is n.
Note that since 2ab = 2ab = 2ba
No, these aren't right.
##2^{ab} = (2^a)^b \neq 2^{a^b}##
For example, ##2^{2\cdot 3} = (2^2)^3 = 2^6 = 64##, but ##2^{2^3} = 2^8 = 256##
But maybe the question was a different one: you did not realize that nothing was being raised to power -1: the guy was just using correct notation (for a subtraction) which a lot of people don't bother with here. :oldtongue:
Understand this:
https://www.math.iupui.edu/~ccowen/OldCoursePages/Math300F07/300F07Quiz4.pdf
My condensed version:
You know you can factor (x-1) out of (x^n-1) because x=1 is guaranteed to be a root of the polynomial (x^n-1) (because whether n is even or odd we will always get zero when x=1).
We write the second factor of our expansion so that it ends in +1. The two factors multiplied together cause a series of cancellations to occur which result in the original expression (x^n-1).
Once this is understood (as someone else mentioned already) plug in 2^ab into (x^n-1) where x=2 and n=ab.
