Solving Heat Transfer Rate for 10 mm Ice Layer at -5°C
  • Thread starter Thread starter debwaldy
    Expansion
The discussion focuses on calculating the rate of increase in the thickness of a 10 mm ice layer at -5°C due to heat transfer. The participant correctly calculated the heat transfer coefficient and heat flux, leading to a derived thickness change rate of approximately 2.799 x 10^-6 m/s. The explanation emphasizes the importance of understanding the flow of heat from the lake surface and its effect on ice formation. Clarification was provided on how to logically approach the problem by considering the heat loss over time and its conversion into ice volume. Overall, the calculations were confirmed to be accurate, enhancing the participant's understanding of the heat transfer process.
debwaldy
hi,i was wondering if someone could tell me if the following solution makes sense,ithink it does but not sure why?
cool air blowing across the surface of a frozen lake keeps the top surface of the ice at a temperature of -5degrees celsius.what is the rate of increase in the thickness of the ice layer when the ice is 10 mm thick?
the density,thermal conductivity and specific latent heat of fusion of ice are 920 kg m^-3, 1.7 J m^-1 K^-1 s^-1 and 3.3*10^5 J kg^-1 respectively
so i said that:
the heat transfer coefficient = thermal conductivity/thickness of material
i.e heat transfer coefficient= 1.7/0.01= 1.7*10^2 J K^-1 s^-1
then i said :
heat flux=(1.7*10^2) *5 = 8.5*10^2
then:
8.5*10^2/920 = 9.23913*10^-1
and so:
9.23913*10^-1/3.3*10^5= 2.799* 10^-6 ms^-1
i know the answer is right but i don't quite understand the thinking behind it.could anyone explain it to me?
any help would be much appreciated:biggrin:
You seem to have done the right sums, but not in a logical order.
Your heat transfer coeff. and heat flux are OK.
Now think about what happens to 1 square meter of lake surface in 1 second.
850 J of heat flows out of the lake. That freezes 850/3.3*10^5 = 2.575*10^-3 Kg of ice.
The volume of the ice is 2.575*10^-3/920 = 2.799*10^-6 m^3.
We were considering 1 square meter of area, so 2.799*10^-6 m^3 is a block of size 1m * 1m * 2.799*10^-6 m.
The time was 1 second, so the thickness changes at 2.799*10^-6 ms-1.
thanks a million,that makes sense to me now alright...wasnt really thinking bout it in a logical manner
thanks for clearing that up!
:biggrin:
