Expectation operator - linearity
Pietair
Show that the expectation operator E() is a linear operator, or, implying:
E(a\bar{x}+b\bar{y})=aE(\bar{x})+bE(\bar{y})
E(\bar{x})=\int_{-\infty}^{+\infty}xf_{\bar{x}}(x)dx
With f_{\bar{x}} the probability density function of random variable x.
aE(\bar{x})=a\int_{-\infty}^{+\infty}xf_{\bar{x}}(x)dx and:
bE(\bar{y})=b\int_{-\infty}^{+\infty}yf_{\bar{y}}(y)dy
Introducing a new random variable:
\bar{v}=a\bar{x}+b\bar{y}
Then:
E(\bar{v})=E(a\bar{x}+b\bar{y})=\int_{-\infty}^{+\infty}vf_{\bar{v}}(v)dv=\int_{-\infty}^{+\infty}(ax+by)f_{\bar{v}}(v)dv
And accordingly:
E(a\bar{x}+b\bar{y})=\int_{-\infty}^{+\infty}(ax+by)f_{\bar{v}}(v)dv=a\int_{-\infty}^{+\infty}xf_{\bar{v}}(v)dv+b\int_{-\infty}^{+\infty}yf_{\bar{v}}(v)dv
So what remains to proof is that:
a\int_{-\infty}^{+\infty}xf_{\bar{v}}(v)dv+b\int_{-\infty}^{+\infty}yf_{\bar{v}}(v)dv=a\int_{-\infty}^{+\infty}xf_{\bar{x}}(x)dx+b\int_{-\infty}^{+\infty}yf_{\bar{y}}(y)dy
And now I am stuck... I don't know how I can relate the p.d.f. of random variable v to the p.d.f.'s of random variables x and y.
Thank you in advance!
Then:
And accordingly:
Haven't you seen some kind of results that gives the pdf of X+Y in terms of the pdf of X and Y?? Hint: it has to do with convolution.
Thank you for your reply.
I know that the probability distribution of the sum of two or more random variables is the convolution of their individual pdf's, but as far as I know this is only valid for independent random variables. While ##E(aX+bY)=aE(X)+bE(Y)## is true in general, right?.
Yes to both.
Depending on the level of rigor required, you may have to qualify things a bit. For example, if Y = -X, then E(X+Y) = EX + EY is false if EX = EY = ∞, because we would be trying to equate 0 to ∞ - ∞, which is not allowed.
So, the easiest way is to assume that both EX and EY are finite. Now you really have a 2-stage task:
(1) Prove the "theorem of the unconscious statistician", which says that if Z = g(X,Y), then
EZ \equiv \int z \: dF_Z(z)
can be written as
\int g(x,y) \: d^2F_{XY}(x,y),
which becomes
\sum_{x,y} g(x,y)\: P_{XY}(x,y)
in the discrete case where there are no densities, and becomes
\int g(x,y) f_{XY}(x,y) \, dx \, dy
in the continuous case where there are densities. Of course, the result is also true in a mixed continuous-discrete case where there are densities and point-mass probabilities, but then we need to write Stieltjes integrals, etc. Then, you need to do the much easier task of proving that
\int (ax + by) f_{XY}(x,y) \, dx \, dy<br /> = a \int x f_X(x) \, dx + b \int y f_Y(y) \, dy = a EX + b EY .
The last form holds in general, whether the random variables are continuous, discrete or mixed. As you say, it holds even when X and Y are dependent.
can be written as
which becomes
Hmm, so there really is no elementary proof?? (I guess it depends on what you call elementary though). This kind of makes me happy that I know measure theory, it makes the proof of this result so much simpler.
There are two things I don't understand about this problem. First, when finding the nth root of a number, there should in theory be n solutions. However, the formula produces n+1 roots. Here is how. The first root is simply ##\left(r\right)^{\left(\frac{1}{n}\right)}##. Then you multiply this first root by n additional expressions given by the formula, as you go through k=0,1,...n-1. So you end up with n+1 roots, which cannot be correct. Let me illustrate what I mean. For this...
