Expectation value r^2 for a radial wave function
The discussion revolves around calculating the expectation value of for the ground state radial wave function of an electron in a hydrogen atom, specifically the 1s wave function. Participants explore the mathematical formulation and integration limits relevant to this quantum mechanics problem.
  • Mathematical reasoning, Assumption checking, Conceptual clarification
  • Participants discuss the correct form of the integral for and question the limits of integration, debating whether to integrate from 0 to a or from 0 to infinity. There is also exploration of the angular components of the wave function and their impact on the integration process.
Some participants have provided insights on the necessity of including the angular components in the integral and the factors that arise from spherical coordinates. There is acknowledgment of the complexity of the integral and attempts to clarify the contributions from various terms.
Participants note the importance of integrating over all possible values of r, while also recognizing that negative values for radius are not physically meaningful. There is a mention of using integral tables and the challenges of formatting mathematical expressions correctly in the forum.
blaksheep423
The ground state (lowest energy) radial wave function for an electron bound to a proton to form a hydrogen atom is given by the 1s (n=1, l=0) wave function:
R10 = (2 / a3/2) exp(-r / a)
where r is the distance of the electron from the proton and a is a constant.
a) Sketch the wave function, and
b) What is the expectation value of <r2> for the electron?
i think the equation for <r2> is
[tex]\int[/tex] R*r2R dr
from -infinity to infinity
for a) i am completely blanking on how to sketch the wave function. for b) i was able to use an integral table to evaluate <r2> and i got 8 / [tex]\sqrt{}a[/tex]
however, i have a feeling that my original equation for <r2> is wrong, and should involve some sort of Y and [tex]\phi[/tex] and [tex]\Theta[/tex]
also, should i be integrating from 0 - a, or -infinity to infinity?
It decays exponentially. It's an exponential function. You just have to sketch it, not even plot it. You should have some idea of what it looks like.
It's true that in general you need to evaluate〈ψ|r2|ψ〉using the entire wavefunction, which in this case means doing the full 3D integral. However, in this case, because l = 0, the angular part of the wavefunction, Y00 is constant (i.e. it is independent of θ and ϕ), making things really easy. You can look up what it is.
Well, you should integrate over all possible r values. But you can't have a negative radius, can you?
You're off by a little bit. In the 1s state, there is actually no angular dependence, but you do need the [itex]4\pi r^2[/itex] coefficient of [itex]dr[/itex]. Thus, your integral should be
[tex] \langle r^2\rangle=\int_0^\infty R^*r^2R\,4\pi r^2dr[/tex]
OK, so i understand that the second r2 term came from r d[tex]\Theta[/tex] r sin[tex]\Theta[/tex] d[tex]\phi[/tex], but where does the 4[tex]\pi[/tex] come from? [tex]\phi[/tex] goes from 0-2[tex]\pi[/tex], but what about the extra factor of 2? Is it because the function is symmetric, so you're now integrating from 0- infinity and multiplying the result by 2?
And what happens to sin[tex]\Theta[/tex] d[tex]\Theta[/tex]?
man, i need a laTex tutorial...
ok, i think I've got it now. if anyone sees an error in this post, let me know.
the integral above comes from integrating sin([tex]\Theta[/tex]) from 0 to [tex]\pi[/tex] = 1, and d [tex]\phi[/tex] from 0 - 2[tex]\pi[/tex] = 2[tex]\pi[/tex]. then, integrating from 0 - infinity gives the extra factor of 2, yielding
<r2> = (4 [tex]\pi[/tex])(4/a3) [tex]\int[/tex] r4 exp(-2r/a) dr -------------- from 0 to infinity
for this particular radial wave function. Right?
Well, with my handy table of integrals, i evaluated this to an obscenely complicated function, which because of the exponential ended up evaluating fairly easily from 0 to infinity. i got
<r2> = 12 [tex]\pi[/tex] a2
ignore the fact that the pi's are all superscripts. i don't know why that's happening.
is this the correct answer?
The [tex]sin(\theta) d\theta[/tex] contributes a 2 which results in the [tex]4 \pi[/tex]
I get that value as well. As for your work not aligning correctly, this is because you are not writing everything in the tex environment. Rather than writing "tex \int /tex r sup4/sup etc "etc (with braces, I'm dropping them so as to show you what i mean) write "tex \int_{bottom limit}^{upper limit} r^4e^{-2r/a}dx /tex" and it'll look pretty:
[tex] \langle r^2\rangle=\frac{3\pi}{a^3}\int_0^\infty r^4\exp\left[-\frac{2r}{a}\right]dx=12\pi a^2[/tex]
Also:
[tex] \int_0^\pi\sin[\theta]d\theta\int_0^{2\pi}d\phi=\int_{-1}^1d(\cos\theta)\int_0^{2\pi}d\phi=(1-(-1))\cdot(2\pi-0)=4\pi[/tex]
  • · Replies 19 ·
  • · Replies 30 ·
  • · Replies 21 ·
