Experimental measurements of relative magnetic permeability
The discussion focuses on measuring the relative permeability of materials using solenoids made with 30 AWG magnet wire around ferrite, steel, and wood cores. The user reports unexpected permeability values, particularly for wood, which should be close to 1, and for steel and ferrite, which should be significantly higher. Suggestions include checking for saturation due to excessive ampere-turns and experimenting with smaller currents. The user asserts that they have verified they are in the linear region and that the relationship between magnetic field strength (B) and current (I) remains linear up to 2A. Despite attempts to account for solenoid dimensions, the results have not improved significantly.
brybot
I am trying to measure the relative permeability of a few materials, but the numbers I'm getting don't quite make sense. Maybe someone here can figure out what might be going wrong.
My setup is as follows. I'm making solenoids using 30 AWG magnet wire wrapped around ferrite, steel and wood cores. I'm doing a single layer of wire and I get about 3600 turns per meter, however the solenoids themselves are about 1"L x 1/4"D. I have a hall effect sensor, the Allegro A1324 which has a sensitivity of 5mv/G. I'm placing the end of the solenoid directly against the sensor and measuring the voltage deviation with respect to current in the solenoid.
With the equation B=kμnI where n=N/L~=3600 I'm solving for the relative permeability k. So k=B/(μnI). At 2 amps I get readings of 201, 170, and 15 G for ferrite, steel, and wood respectively. Then solving for the relative permeability I get 2.2, 1.9 and 0.17. Wood should have something close to 1, so I know something is wrong. And the steel/ferrite should be at least 200.
Any ideas? Thanks
Welcome to Physics Forums. :smile:
Quite possibly your ampere-turns per meter was excessive, and the magnetic materials were driven into saturation. Repeat using much smaller currents.
What value do you get if there is no core in the solenoid?
Thanks for your reply. I'm in the linear region, I've verified experimentally. I'm not sure where saturation will occur, but the relationship between B and I is very linear from 0-2A for these solenoids. Also, 3600 turns per meter is a relatively small value as far as I'm aware.
@ Nasu, I used the wood to mimic an air core. The wire is flimsy and would not hold the shape on its own. Wood and air should both be very close to 1.
I did find another equation for non-ideal solenoids where the length and radius are taken into account. The results did not improve much.
Thread 'Griffith, Electrodynamics, 4th Edition, Example 4.8. (Second part)'
I am reading the Griffith, Electrodynamics book, 4th edition, Example 4.8. I want to understand some issues more correctly. It's a little bit difficult to understand now. > Example 4.8. Suppose the entire region below the plane ##z=0## in Fig. 4.28 is filled with uniform linear dielectric material of susceptibility ##\chi_e##. Calculate the force on a point charge ##q## situated a distance ##d## above the origin. In the page 196, in the first paragraph, the author argues as follows ...
Thread 'Inducing EMF Through a Coil: Understanding Flux'
Thank you for reading my post. I can understand why a change in magnetic flux through a conducting surface would induce an emf, but how does this work when inducing an emf through a coil? How does the flux through the empty space between the wires have an effect on the electrons in the wire itself? In the image below is a coil with a magnetic field going through the space between the wires but not necessarily through the wires themselves. Thank you.
