Explain why -sin[SUP]2[/SUP]x - cos[SUP]2[SUP]x = -1
  • Thread starter Thread starter tjohn101
    Explain
tjohn101
I should know this, but I'm using it as a step in one of my proofs and having trouble explaining how it works. Can someone help?
-sin2x - cos2x = -1
Not sure how to prove and explain it.
And sorry about the title gents I'm using a blackberry so I just copied and pasted the equation from my question : /
Derived from what? If you know that [math]sin^2(x)+ cos^2(x)= 1[/math], then just multiply both sides of that equation by -1.
If you cannot use that, how you prove it depends upon the precise definition of sine and cosine. What definitions are you using?
Not sure. I'm proving d/dx [cotx] = -csc2x and I have the above equation in there as a step towards my proof. I've proven it, but my professor wants me to explain why the above equation = -1.
It's crucial to know what you're allowed to assume. If you can assume sin^2x + cos^2x = 1, then just multiply both sides by -1 and you get that equation. If you can't assume that, you can draw out a triangle and prove that sin^2x + cos^2x = 1 from the definitions of sine and cosine.
it's the pythagorean theorem. Assume a right triangle formed by a vector and the x,y axes with sides A, B, C. Assume you're looking at angle "a": sin(a)=A/C cos(a)=B/C. Plug those in and multiply both sides by C^2 to get A^2+B^2=C^2
There are two things I don't understand about this problem. First, when finding the nth root of a number, there should in theory be n solutions. However, the formula produces n+1 roots. Here is how. The first root is simply ##\left(r\right)^{\left(\frac{1}{n}\right)}##. Then you multiply this first root by n additional expressions given by the formula, as you go through k=0,1,...n-1. So you end up with n+1 roots, which cannot be correct. Let me illustrate what I mean. For this...
