Explaining the Twin Paradox: A Big Problem?
  • Context: Undergrad
  • Thread starter Thread starter Marilyn67
    Paradox Twin paradox
33 replies · 3K views
Marilyn67
TL;DR
Theoretically the situation is symmetrical and the question does not make sense....
This question sounds very simple, (college) but I would like the advice of an expert.
I will explain the reason later.
Hello,
For many years, solving the twin paradox has not been a problem for me.
I understood that it is the change of Galilean frame of reference that is responsible for the age difference, and this clearly appears on a Minkowski diagram. Okay.
However, since yesterday, in wanting to explain this famous and well-known paradox (which is not one) to a student, I encountered a problem.
A big problem !
If we consider two twins moving away from each other in a uniform rectilinear motion and never seeing each other again, relativity teaches us that there is no possible answer to the question of "which clock" is really the slowest. (that's what I learned).
The situation is symmetrical and the question does not make sense.
You confirm ?
No, not a Galilean frame, a Lorentz frame. And no, just changing frames is not what is responsible for the age difference.
That's correct. And in this scenario, there is also no "twin paradox", because the two twins never meet up again to compare their elapsed times.
The "twin paradox" only occurs if the two twins do meet up again and can compare their elapsed times since they were last together, and find that they are different. But for that to happen (at least in flat spacetime; gravity and curved spacetime introduce further complications), at least one of them cannot remain for all time in uniform rectilinear motion.
Thank you PeterDonis,
Okay.
I understood your two answers correctly.
Here is my problem:
Let us suppose our solar system and Vega as representing the same frame of reference.
Suppose a spaceship leaves our solar system (thanks to very rapid acceleration).
The spacecraft is now moving away from Earth in uniform rectilinear motion at relativistic speed with a lorentz factor equal to 10.
Vega is 25 light years away, and the ship passes Vega (without stopping) after about 25 years from Earth's perspective.
It's correct ?
Changing (Lorentz!) frame is responsible for the discrepancy between a naive application of time dilation from the traveller's perspective and reality, yes. But the underlying reason for the difference in ages is effectively the triangle inequality as it applies to Minkowski geometry.
I would avoid words like "really". Rather, I would say that there is no unambiguous answer to which is slower. You can only unambiguously compare clocks if they are in the same place, and inertial clocks in flat spacetime are only at the same place once, so have no way to calculate an elapsed time.
Thank you Ibix,
I agree
My problem is this :
For astronauts, the spacecraft crosses Vega (without stopping) after two and a half years.
(the "rapidity" represent the speed of light multiplied by 10)
It's correct ?
A big problem !
Marilyn67 said:
Here is my problem:
What is the problem exactly?
The big question is this :
The fact that in one frame of reference, the trip lasts 25 years and that in the other frame of reference, the trip lasts two and a half years does not constitute proof that it is the clock of the spaceship that is lagging?
(In contradiction with the symmetry evoked before ?)
In summary, the observation of the rapidity doesn't make it possible to make sense to the movement of the clocks which should be symmetrical ?
(I specify that the spaceship continues its trip and doesn't stop at Vega !)
It's correct ?
Yes, assuming as long as by "after about 25 years" you mean some time longer than the 25 years it would tke for a flash of light to make the same journey.
These problems are easier to work with if you choose the speed to be either ##\frac{3}{5}c## or ##\frac{4}{5}c## so that the Lorentz factor comes out a nice round fraction: either ##\frac{5}{4}## or ##\frac{5}{3}##. So let's take the speed to ##\frac{3}{5}c## and the distance traveled to be 15 light-years (it's an example so might as well choose numbers that make the arthmetic easy).
Now the journey will take 25 years according to someone on Earth, and if we use the frame in which the Earth is at rest to assign coordinates to the three relevant events in this example:
Event 1, x=0, t=0: Traveller sets out on journey, both clocks are set to zero
Event 2, x=15,t=25: Traveller arrives at destination
Event 3, x=0, t=25: Clock on Earth reads 25
Now use the Lorentz transformations to calculate the coordinates (call them x' and t') because tht's how the transformations are usually written) of these three events using the frame in which the ship is at rest. Looking at these results, you and your student will be able to see that:
- The question of which one is "really" slow really has no answer; the answer depends on your choice of frame.
- Relativity of simultaneity is why there is no paradox in having both clocks slower than the other
- The situation really is completely symmetrical
But do note that, as @PeterDonis pointed out above, this is not the Twin Paradox. For that you'd need to bring the traveller back home again so that they could compare their clocks while at the same point in space; the paradox is that despite the symmetry of the time dilation formula the traveller ends up aged less.
Thanks Nugatory,
Yes, I understood PeterDonis' answer correctly.
However, the comparison of different rapidity isn't an "exception" that allows to answer the same question, without comparing the clocks in the same place ?
I know the idea is crazy !
It is for this reason that I ask the question!
What contradiction? Are you ignoring the length contraction?
No, I don't ignoring the length contraction.
But that doesn't answer the question...:oops: ?
By comparing the rapidity, one could break the symmetry, which is contradictory to the fact that the question of which clock is slower does not make sense.
I don't assert
I ask the question because it seems crazy to me :oops:
You break the symmetry by using a third object, that is at rest in one frame, but not in the other.
Why speak of a third object ?
I'm only talking about referentiel and there are only two. (?)
Earth, Vega, spaceship
Looks like 3 to me.
It's correct ?
In relativity, "rapidity" is a technical term that describes the Minkowski-analogue of an angle [itex]\theta[/itex] between inertial worldlines (between their 4-velocities) such that their relative-velocity is [itex]v_{BA}=c\tanh\theta[/itex].
Maybe you mean "time-dilation factor" [itex]\gamma=\frac{1}{\sqrt{1-(v/c)^2}}=\cosh\theta[/itex].
It is not. Rapidity is an alternative (and in some ways more mathematically convenient) way of representing relative velocities, but it doesn't eliminate the basic symmetry: take A to be at rest while B is moving, or B to be at rest while A is moving, and all physical results will come out the same.
The issue with comparing clocks at different locations is that any such comparison involves a statement of the form "at the same time that clock A reads ##T_A##, clock B reads ##T_B##"; the phrase "at the same time" pretty much guarantees that the result of the comparison will be frame-dependent.
It is not what is responsible for the age difference, but it does unambiguously show that there is asymmetry.
This is not a contradiction. In the spaceship’s frame the Earth and Vega clocks are not synchronized.
Meaning, they are at rest relative to each other? Ok.
It's correct ?
If you assume that Earth and Vega clocks are synchronized using the Einstein clock synchronization procedure, and the ship leaves Earth at Earth time zero, then when the ship passes Vega, it will observe the clocks on Vega to read time 25 years, yes.
What's the problem?
It's correct ?
Meaning, if the ship's clocks are set to time zero when the ship leaves Earth, then when the ship passes Vega, the ship's clocks will read time 2.5 years, yes.
What's the problem?
No. You have left out relativity of simultaneity. (A good rule of thumb in SR problems is that if you are confused, it's because you have left out relativity of simultaneity.)
In the ship's frame, as has been noted, Earth and Vega clocks are not synchronized. In the ship's frame, when the ship leaves Earth, Earth clocks read time zero, but Vega clocks read time 24.75 years. In the ship's frame, Earth and Vega clocks run slow by a factor of 10 (same Lorentz factor), so the trip that takes 2.5 years by the ship's clock, in the ship's frame, takes 0.25 years by Earth and Vega clocks. So when the ship passes Vega, it sees Vega clocks read 24.75 + 0.25 = 25 years. And in the ship's frame, Earth clocks at that same time (when the ship passes Vega) read time 0.25 years. So Earth clocks, according to the ship's frame, run behind Vega clocks by 24.75 years.
@Marilyn67 if you go through the exercise I outlined in post #10 up above, you will see how the relativity of simultaneity comes in.
@Marilyn67 Or maybe you mean proper velocity?
https://en.wikipedia.org/wiki/Proper_velocity
Hello,
Excuse me for the late reply and also for my not very good English (I am French and I live in France).
I thank all the participants for their very clear answers which all show that I was wrong.
(7 messages this morning! Thank you!)
You are right, that has been the source of my confusion.
We may well know that simultaneity is relative, our "absolute" daily life makes us continually make mistakes.
Yes
I am ashamed ! :blushing:
The worst part is that I learned it !
Without considering the relative simultaneity, I deduced naively and too quickly that 2.5 years in the spacecraft corresponded to 25 years on Earth, from the point of view of the spacecraft , while it is obviously the reverse, so 0.25 years !
(I had made a calculation a long time ago with the famous hypothetical tachyon exchanges using this phenomenon to demonstrate that if tachyons existed, they violated the principle of causality by allowing information to be sent in the past :wink: ).
A question torments me, again :
I thought that by considering the Earth and Vega fixed between them, the Earth and Vega represented 2 different landmarks, but in the same frame of reference. You agree (# 22) that Earth and Vega can be considered a single frame of reference, but @A.T. sees 2, so 3 in total. However, it is theoretically possible to synchronize all the remote landmark clocks in the same frame of reference, since the landmarks are fixed between them, right ?
The key question is what relative motion do we have?
1) The Earth and Vega are at rest relative to each other.
2) The spaceship is moving relative to the Earth and Vega.
You can study any problem in any inertial reference frame you want. In this case, however, there are two obvious frames that are the most useful:
1) The reference frame in which Earth and Vega are at rest.
2) The reference frame in which the spaceship is at rest.
All clocks at rest in an inertial reference frame can be synchronised (see Einstein synchronisation convention) - and this is the basis on which the Lorentz Transformation applies. In this case, therefore, we assume that clocks on Earth and Vega are synchronised in this way.
In the reference frame in which the ship is at rest, however, these clocks are not synchrosied - and the relativity of simultaneity applies.
No, I didn't say that Earth and Vega are two different reference frames. I said that your scenario has no symmetry between the two frames: You have two objects at rest in one frame, but only one object at rest in the other frame. To have symmetry you would for example need two spaceships at relative rest to each other, separated by the same proper distance as the planets. Only then you could claim symmetry, and would find corresponding durations which would be the same from either frame.
Let me try the original scenario, but keeping it as symmetrical as I can make it.
Earth and Vega are 25 LY apart and stationary relative to each other. They are said to have a proper separation of 25 LY. The ship (which is always inertial, never accelerating) is 25 LY in proper length and moving at v=+.995c relative to the planets, and the planets are thus moving at v=-.995c relative to the ship.
We now have 2 frames and 4 objects (Earth, Vega, Nose, Tail). The clocks on the planets are synced in the planet frame, and the clocks at opposite ends of the ship are synced in ship frame. Note that the two ship clocks are not synced in the planet frame, nor are the two planet clocks synced in the ship frame.
Lorentz factor is 10.
Planets frame:
At event A (x=0@Earth, t=0), the nose is at Earth and the Earth clock and nose clock both read t=t'=0.
The ship is contracted to 2.5LY in Earth frame, so the tail passes Earth (event B) at x=0, t=2y187d, and the tail clock reads t'=25y46d as it passes.
It takes the nose about 25 years 1.5 months to get to Vega (x=25, so at event C (nose at Vega), the Vega clock reads x=25, t=25y46d and the time dilated nose clock reads x'=0, t'=2y187d. The tail of the ship passes Vega at event D, x=0, t=27y233d.
In ship frame, the nose is at location x'=0 and the tail at x'=-25. The ship is stationary so these don't change.
At event A (x'=0, t'= 0), the Earth is at the nose and the Earth clock and nose clock both read t=t'=0.
The separation between the planets is contracted to 2.5LY in ship frame, so Vega passes the nose (event C) at x'=0, t'=2y187d and the Vega clock reads t'=25y46d as it passes.
It takes the Earth about 25 years 1.5 months to get to the tail (x'=-25, so at event B (Earth at tail), the tail clock reads x'=-25, t'=25y46d and the time dilated Earth clock reads t=2y187d. The Vega passes the tail of the ship at event D, x'=-25, t'=27y233d.
Now it seems to be completely symmetrical.
