Exploring Binomial Expansions and Factorials in Sequences and Series
In summary, the conversation involves finding the value of P1Q1+P2Q2+...+Pn-1Qn-1, given the equations P r=(n-r)(n-r+1)(n-r+2)...(n-r+p-1) and Qr= r(r+1)(r+2)...(r+q-1). The suggested approach is to expand the equations and manipulate the terms to simplify the final expression. The source of the problem is from the book "HIGHER ALGEBRA" by Hall&Knight, and the result involves factorial notations. The conversation suggests evaluating the terms P1, P2, ..., Pn-1 and Q1, Q2
Vineeth T
31
If P r=(n-r)(n-r+1)(n-r+2)...(n-r+p-1)
Find P1Q1+P2Q2+...
+Pn-1Qn-1
I tried to bring the general term in the form of a coefficient of x in the binomial expansion.
But it does not simplify to that form.
can anyone give me a better way to approach the problem?
Its a lot of messing around with, but I'll give you the basic idea, note that when you expand, the integers turn out to be sum of squares, that is (n-1)(n)(2n-1)/6. The rn turn out to be (n-1)rn. You just do this to the different terms to get the final thing, which then you might be able to factor out. Try doing this and post your result, shouldn't be too hard.
Thanks, Bonaparte
Thanks, Bonaparte
Can you explain it more clearly?
Also the source of this problem is from a book called "HIGHER ALGEBRA" by Hall&Knight.
If you have this book see the answer (only the final result is given) in pg:328.Q no:27
The answer even has factorial notations in it.
Try evaluating P1 , P2 , ... , Pn-1 ...
Then Q1 , Q2 , Q3 , ... , Qn-1...
Don't over simplify...
Then You evaluate P1Q1+P2Q2+...
+Pn-1Qn-1...
First do this much. What do you get ?
Related to Exploring Binomial Expansions and Factorials in Sequences and Series
What is a sequence?
A sequence is a list of numbers arranged in a specific order. Each number in the sequence is called a term and the position of the term in the sequence is called its index.
What is a series?
A series is the sum of all the terms in a sequence. It is denoted by the Greek letter sigma (∑) and the starting and ending index of the terms are usually indicated below and above the sigma symbol respectively.
What is the difference between an arithmetic sequence and a geometric sequence?
An arithmetic sequence is a sequence where the difference between any two consecutive terms is constant. A geometric sequence is a sequence where the ratio between any two consecutive terms is constant. In other words, in an arithmetic sequence, the terms increase or decrease by a fixed amount while in a geometric sequence, the terms increase or decrease by a fixed ratio.
What is the formula for finding the nth term of an arithmetic sequence?
The formula for finding the nth term of an arithmetic sequence is:
an = a₁ + (n-1)d
where an is the nth term, a₁ is the first term, and d is the common difference.
What is the formula for finding the sum of a finite arithmetic or geometric series?
The formula for finding the sum of a finite arithmetic series is:
Sn = (n/2)(a₁ + aₙ)
where Sn is the sum of the first n terms, a₁ is the first term, and aₙ is the nth term.
The formula for finding the sum of a finite geometric series is:
Sn = (a₁(1-rⁿ))/(1-r)
where Sn is the sum of the first n terms, a₁ is the first term, and r is the common ratio.
  • Precalculus Mathematics Homework Help
