How Do Cooling Towers Function in Nuclear Reactors?
  • Thread starter Thread starter McLaren
    Cooling
Cooling towers in nuclear reactors primarily function to dissipate heat from the reactor's coolant system. Most cooling towers are of the "wet" type, where warm water from the reactor is cooled by air flow, facilitated by the tower's height, which enhances airflow through the structure. As warm air rises, it creates a vacuum that draws in cooler air, promoting heat exchange. This process not only cools the water but also causes some of it to evaporate, effectively removing heat. However, a key challenge with wet cooling towers is the need to replenish water due to evaporation losses.
McLaren
[SOLVED] Cooling Towers
I was just wondering how cooling towers in nuclear reactors work. I've read many different versions of a cooling tower's task, but they all seem to be different from one another. I'm writing a webpage on nuclear energy and was just wondering.
Thank you all very much
It seems like you can have two different types of cooling towers 'dry' and 'wet' see the link:
http://www.madison.k12.wi.us/stugeon/mini1.html
EDIT: and an even better one:
http://www.umich.edu/~gs265/society/nuclear.htm
Its quite simple really (and most are the "wet" type - you can tell by the steam). The water is hot. The tower is actually supported a few feet (can't remember how high - 10 or 20 feet probably) above the ground. At the base of the tower, there is a series of waterfall type structures around the perimeter and a collection pool inside at the bottom. Air can flow into the base of the tower. The warm water in the pool warms the air over it, and since warm air rises, it rises up inside the tower. That process pulls more air into the tower through the waterfall type structure. And the higher the tower, the higher the airflow since it has a longer distance in which to gain speed. The cooling comes in two ways: Cool air going through hot water cools the water. Cool air going through warm water also makes some water evaporate. Evaporation is essentially slow boiling - so it removes a LOT of heat from the water when a little evaporates.
The problem of course with a "wet" tower is you need to replenish the water supply as it evaporates.
I have Mass A being pulled vertically. I have Mass B on an incline that is pulling Mass A. There is a 2:1 pulley between them. The math I'm using is: FA = MA / 2 = ? t-force MB * SIN(of the incline degree) = ? If MB is greater then FA, it pulls FA up as MB moves down the incline. BUT... If I reverse the 2:1 pulley. Then the math changes to... FA = MA * 2 = ? t-force MB * SIN(of the incline degree) = ? If FA is greater then MB, it pulls MB up the incline as FA moves down. It's confusing...
