Exponential expansion and Higgs mechanism
The discussion centers on the implications of a positive cosmological constant for the universe's expansion and its potential effects on fundamental physics, particularly the Higgs mechanism. Participants explore theoretical frameworks, including General Relativity and quantum field theory, while considering the nature of dark energy and its possible behaviors.
  • Some participants propose that the universe's positive cosmological constant leads to exponential expansion, potentially affecting subatomic spacetime and the Higgs mechanism.
  • Others argue that local interactions, such as those at subatomic scales, remain unaffected by cosmic expansion as long as the event horizon grows or remains constant.
  • A participant questions the evidence supporting the idea that expansion does not impact short distances, suggesting it may be an inference rather than a confirmed observation.
  • Some suggest two approaches to understanding the problem: one using General Relativity and the other employing quantum field theory in a curved spacetime background.
  • Concerns are raised about the "Big Rip" scenario, with some participants suggesting that it may not occur due to theoretical constraints in General Relativity.
  • Discussions include the nature of dark energy and whether it could grow over time, with some participants asserting that no known mechanism allows for such growth.
  • There is mention of the conjectured decay of the cosmological constant, with a participant speculating that if it can decay, it might also grow, although this is contested.
  • Some participants highlight that growing dark energy would violate energy conditions in General Relativity, while others note that inflation is a minimal extension of existing physics compared to the implications of growing dark energy.
Participants express a range of views on the implications of the cosmological constant and dark energy, with no consensus reached on the potential for a "Big Rip" or the nature of dark energy's behavior. The discussion remains unresolved regarding the impact of cosmic expansion on subatomic interactions and the validity of different theoretical approaches.
Limitations include the dependence on theoretical models and assumptions about dark energy and the cosmological constant. The discussion reflects ongoing uncertainties in the field regarding the implications of cosmic expansion for fundamental physics.
lark
Our universe apparently has a positive cosmological constant so it will look more and more like de Sitter spacetime, expanding at at exponentially increasing rate.
So eventually it seems that subatomic spacetime would be affected by this. Eventually even something a Planck distance away would be outside a particle's event horizon.
I wonder if this would tear the Higgs mechanism to pieces …
Laura
Space news on Phys.org
Laura
Nah, in order for subatomic interactions to be affected in the way you suggest, you would need the horizon to shrink. Basically, not everything expands. Local matter that is bound together and much smaller than the horizon scale isn't impacted by the overall expansion at all. So as long as the horizon grows or stays the same (as it will if we have a cosmological constant), it just won't impact local interactions, let alone subatomic ones.
I see. I thought the horizon would shrink since the expansion is exponential, but I guess not.
Laura
I heard this explanation many times but I never understood if there is actual evidence for it or is just an inference.
Perhaps it is just our inability to measure the expansion (if it exists) over short distances.
There are two separate ways to approach this problem. First, you could approach the problem by considering General Relativity alone, and see what happens when you transition from the perfectly smooth, homogeneous universe of the FLRW metric to one in which matter is clumpy. If you do that, it's relatively easy to show that once a clump of matter forms, it remains stable as the expansion continues.
The second way is to do quantum field theory in a curved space-time background. This is probably a good way to reconcile quantum mechanics and gravity when the quantum mechanical behavior doesn't have much of an impact on the gravitational behavior (as is the case for subatomic interactions in a large expanding universe). In that case, it's trivial to show that the space-time curvature of a universe with such a tiny cosmological constant as the one we measure is so incredibly low that it just doesn't make any noticeable difference.
Thank you Chalnoth, it is exactly as I thought.
If the cosmological constant were increasing in time, there could be a "Big Rip" where eventually all matter is torn apart, and perhaps the Higgs mechanism that creates rest mass would be destroyed.
I guess that wouldn't de Sitter space, it would have some other geometry.
Laura
I hope I'm not wrong, but from what I remember H has a logarithmic growth to a limit value.
That mean "Big Rip" Theory has been disproven.
It has? On a quick web-search, I found something http://www.universetoday.com/36929/big-rip/" the likelihood of the Big Rip ever taking place is substantially diminished because evidence indicates dark energy isn't growing in strength.
This doesn't sound very definitive though, and I didn't find anything more definitive.
Most of the reason to believe that a big rip won't happen is theoretical in nature. Basically, you have to violate certain energy conditions in General Relativity (namely the fact that matter has positive mass).
Why would it require negative-mass matter? It's just the idea that dark energy, whatever that is, is getting stronger.
Well, it has to do with the details of General Relativity. There are a couple of ways of looking at it, but if there exists some matter that grows in energy density with time, then that matter has pressure that is both negative and greater in magnitude than its matter density. This large negative pressure leads to a negative mass density for some observers.
The dark energy could be the cosmological constant, which isn't matter. That could decay or grow.
There is no known physical mechanism that could cause it to grow.
I saw papers online about the conjectured decay of the cosmological constant, i.e. tending to zero. If it can decay, it could grow also, I guess.
Sure, the Big Rip would involve new physics. But so do other theories, including inflation.
Laura
Well, again, decaying is no problem because it doesn't violate any energy conditions. Growing is a problem because it requires a pressure that is larger than its energy density, violating the weak energy condition.
Laura
While true, inflation is a minimal extension of existing physics. Growing dark energy is not.
  • · Replies 23 ·
  • · Replies 0 ·
  • · Replies 22 ·
  • · Replies 23 ·
  • · Replies 24 ·
