Exponents & Mods: What You Need to Know
  • Thread starter Thread starter Sam Anderson
The discussion focuses on understanding modular arithmetic in the context of exponents and tetration, specifically regarding the expression ^n3, which represents a power tower of threes. Tetration is formally expressed as 3^{3^{...^3}} with n threes, and Knuth's up arrow notation is used to denote this operation. A participant suggests using induction to prove that ^n3 mod 10 equals 7 for n greater than 1, starting with the base case of 3^3. The proof involves showing that the pattern holds for subsequent powers. The conversation emphasizes the relationship between modular arithmetic and exponentiation in advanced mathematical contexts.
Sam Anderson
Could somebody at least tell me about mods in exponents?
Mathematics news on Phys.org
Sam Anderson said:
Let 3^n denote 333... (n+1 threes in total)
Tetration already has a formalized expression.
^n3=3^{3^{...^3}} with n 3's in the stack.
Or you can even use Knuth's up arrow notation. Exponentiation is denoted by 1 up arrow, and tetration by 2, so
^n3 = 3\uparrow\uparrow n
So what's your question?
Thanks for the quick reply, but I wasn't finished typing. I accidentally hit enter. Sorry.
I could only guess what you're asking for, but if I were to guess, say you want to prove that ^n3 \mod 10 = 7, n>1 we would do an inductive proof. I'll make it short and you can fill in the details, but essentially you start with the base case 3^3 = 27 hence 27 \mod 10 = 7 and we can then show by calculation that 3^7 \mod 10 = 7 hence it must be true for all n.
Seemingly by some mathematical coincidence, a hexagon of sides 2,2,7,7, 11, and 11 can be inscribed in a circle of radius 7. The other day I saw a math problem on line, which they said came from a Polish Olympiad, where you compute the length x of the 3rd side which is the same as the radius, so that the sides of length 2,x, and 11 are inscribed on the arc of a semi-circle. The law of cosines applied twice gives the answer for x of exactly 7, but the arithmetic is so complex that the...
Thread 'Unit Circle Double Angle Derivations'
Here I made a terrible mistake of assuming this to be an equilateral triangle and set 2sinx=1 => x=pi/6. Although this did derive the double angle formulas it also led into a terrible mess trying to find all the combinations of sides. I must have been tired and just assumed 6x=180 and 2sinx=1. By that time, I was so mindset that I nearly scolded a person for even saying 90-x. I wonder if this is a case of biased observation that seeks to dis credit me like Jesus of Nazareth since in reality...
Fermat's Last Theorem has long been one of the most famous mathematical problems, and is now one of the most famous theorems. It simply states that the equation $$ a^n+b^n=c^n $$ has no solutions with positive integers if ##n>2.## It was named after Pierre de Fermat (1607-1665). The problem itself stems from the book Arithmetica by Diophantus of Alexandria. It gained popularity because Fermat noted in his copy "Cubum autem in duos cubos, aut quadratoquadratum in duos quadratoquadratos, et...
