Expressing Newton's 2nd law in terms of momentum
The discussion centers on expressing Newton's second law in terms of momentum, specifically proving that the sum of forces equals the rate of change of momentum (ΣF = dp/dt). Participants clarify that when mass (m) is constant, the derivative of momentum (p = mv) results in m multiplied by the derivative of velocity (dv/dt), which is acceleration (a). This leads to the conclusion that ΣF = ma, reinforcing the relationship between force, mass, and acceleration. The conversation emphasizes the importance of understanding how derivatives work with constants and variables in this context. Overall, the thread effectively elucidates the derivation of the second law from momentum principles.
Calpalned
Show that ##\Sigma \vec F = \frac {d \vec p}{dt} ##
##\Sigma \vec F = m \vec a ##
## \vec a = \frac {d \vec v}{dt} ##
## \vec p = m \vec v ##
We need to prove that ## \frac {d \vec p}{dt} = m \vec a ##. When I physicists correctly take the derivative of ## \vec p ##, they get ## m \vec a ##. How come taking the derivative doesn't affect ##m## ? If ##m## is constant, shouldn't it go to zero?
I know that I am wrong somewhere, but I want to fully understand how this formula was derived.
The method to find derivative of such a function is different.
When derivative of 'only' the constant is taken, it is zero.
When a constant is multiplied with some function, the derivative of the resulting function is the constant multiplied with the derivative of the function.
F=dp/dt
F=d(mv)/dt
F=m dv/dt
F=ma.
Edit: the V is not to be here.
F=dp/dt
F=d(mv)/dt
F=m dv/dt
F=ma.
Hope it helped
Yes, that makes sense.
Normally, if ##\vec v## is a variable and ##m## is a constant, the derivative of ## m \vec v ## will become ##m##. Is ##\vec v## not a variable here?
Second law of motion states that, "The rate of change of momentum is directly proportional to the force applied. "
Now p = mv
We take m as constant, because rate of change of mass in situations involving second law of motion is negligible (you can consider rocket propulsion as an example in which mass varies significantly with time).
taking derivative both sides with respect to time (t),
ΣF ∝ dp/dt
ΣFd(mv)/dt
ΣF m.dv/dt
ΣF ∝ ma (a = acceleration = d(v)/dt )
ΣF = kma (k = proportionality constant = 1, in SI units)
ΣF = ma
Since, you are taking derivative of velocity with respect to time equals to 1 instead of acceleration, that is why you are getting on that result.
V has nothing to do here. kick it out.
V is the variable.
But derivative of mv isn't m. It is m multiplied by derivative of v with respect to time.
Derivative of velocity with respect to time is nothing but acceleration
Likes ToBePhysicist
